It will not be as sharp.
It most likely is 720P so that means 720 pixels across 24+- inches.
A pc monitor has 720 pixels across 15+- inches, much sharper than a tv screen.
It will work via dvi but you should know that the pixels are twice the size. That means jaggy.
