Count me among the lucky but this is the first time I've had to deal with an Acer system.
Background --system crashed due to AOL ver6.0/virus/ HW failure --not sure. System will not boot from a Win 98 Start disk, either hangs at the install of the CD or stops after text in non-CD command. Tried booting from the repair disk and from Win 2000 full version, the system reads boot info from CD and then does an immediate reboot. Looked all over for a jumper to clear the CMOS, no luck. Removed the battery and shorted out the terminals, no luck. One time saw a memory error message, replaced memory, no luck. Seem to get frequent mouse or KB error message on boot up too. I was able to FDISK and Format with an old Win 95 boot disk, one interesting thing, it reported the HD size incorrectly, 2.4g instead of 6.4G, system shows correct. I also tried a different CD, mover the CD to Pri. slave and Sec. Master with no luck either. I was able to get into the Bios if that helps any.
I have to believe it's a MB problem. Can anyone point me in a direction to track down the problem?
