Old, used Lexus RX. How are they? In general?
ibex333
4,094
123
So I have someone offering me a used 2004 RX with 117k miles for 5k.
I think it's not a bad deal. Generally these seem reliable from what I heard. I could be wrong though, because I don't know all that much about cars.
In your experience, are Lexuses more expensive to repair when they break down as compared to Toyotas? Do they require premium gas?
Any other thoughts/suggestions? Thanks!
dasherHampton
2,668
556
My sister had one from that time period. She absolutely loved it, said it was reliable as can be.
I DD an LS 460. It's a joy, but it's not "cheap luxury" like some people think. The power train is about as bullet proof as they come but things do require service, and if you go to a Lexus dealer its not cheap at all.
My average service bill is over $1000.
It does require premium fuel.
Feb 25, 2011
16,994
1,622
Whether or not they require premium depends on the model. Mostly, they're using the same engine as the Toyota models that require regular gas - if the engine is tuned to produce more power w/ premium gas, the computers are still "smart" enough to slow down timing and operate in "Toyota" mode when you don't give them premium. I wouldn't put a lot of stock in the "87-octane killed my engine!" claims that float around. Something something deposits something something, blah blah I drive like a jerk and wore out my engine bits.
That said, premium gas is a real thing, and should give you closer-to-advertised performance, if that matters to you. I also think the engine sounds ever so slightly different, which may be psychosomatic, or may be my really, really good hearing. (I was tested!)
As far as repair costs, it depends partially on parts commonality and availability. For example, an ES series has pretty much all its drivetrain components in common with an Avalon, and a lot in common with a Camry, so parts are easy to find. I'm not so sure about an RX.
Certainly body panels and trim will be rarer/pricier.
The maintenance costs are going to be a lot more dependent on where you take it, because the main cost is the labor, not the parts/fluids. Luxury (and even not-luxury) car dealerships around here charge half again to double what a decent independent mechanic charges. ($90-$100 vs. $150-$180.) But anybody can do oil changes, tire rotations, fluid swaps, and other required maintenance.
@dasherHampton - at $1,000 per trip, I think your dealership may be screwing you pretty hard there.
dasherHampton
2,668
556
Maybe its high, but its included stuff like brakes, tires, major interval service etc
I'd rather go to Lexus and pay a little more.
How does a person without any special setup rotate tires by themselves without major hassle?
NutBucket
27,154
635
Uh, two floor jacks?
Or for my cars I can get away with one; suspension is stiff enough I can lift the front and rear with a single jack up front.
Feb 25, 2011
16,994
1,622
It's up to you. your money and whatnot. But for things like fluid changes and other "major service interval" stufff, my indie place is usually coming in at under half the price of a dealership.
You should also be getting oil changes and stuff done a lot more often than your major service intervals. If every visit is costing you $1k, that's terrible, but if you're just getting $1k bills every 30-45k miles and are doing oil changes and whatnot more frequently for $50 each, that's less bothersome.
Brakes I do myself, because I have no desire to spend $500 to have a dealership replace $250 worth of parts that I can buy on Amazon for $125. I have the money, I shouldn't care, but it's literally offensive to me.
An independent mechanic is going to still have a "special setup" so I'm not sure what you're getting at, but to answer the question, you need a $20 floor jack and two $15 pairs of jack stands. Jack it up, put it on the stands, take all the tires off, and put them on in the different places where they go. A breaker bar is helpful too.
https://www.tirebuyer.com/education/tire-rotation-patterns
pauldun170
9,509
5,731
Any shop that can fix a Highlander from that era will have no problem with a RX330.
Just remember that that engine uses a timing belt. The service interval is every 70K ( I think).
Those cars are pretty well built that should hold up for a years. I don't recall any design or engineering quirks that should concern you.
At that age and mileage, it should be a turn key car. At most the throttle body might need a good cleaning.
Reactions: ibex333
T2urtle
3,432
The 300s might be sludge prone. Non interference motors if I recall.
330s are timing belt with interference motors.
Both are good motors tho. I thought about getting one myself but if I was to get something that vintage I might try a 4 cylinder highlander.
Try not to get gold on gold. Most on the road are gold on gold.
Sent from my iPhone using Tapatalk
evident
12,139
761
We have an 07. My wife loves it. I do most of the maintenance on it. Pretty reliable, but check out clublexus for year specific issues. I think maybe waterpump may quit early. Maintenance in general is not more expensive than the equivalent toyota highlander.
pauldun170
9,509
5,731
The only thing with the 4banger Highlanders of that era is that there is a stripped head bolt issue on the 2.4. Impacts 2002-2006.
Just spent a good 5 minutes trying to recall an RX330 that was NOT gold.
lol
Reactions: HotJob
evident
12,139
761
Oh yeah, i think another issue is the rack and pinion may have power steering fluid that may leak. It's about a $600 repair, but it's extremely slow.
dasherHampton
2,668
556
I certainly don't want to argue car maintenance with experienced do it yourselfers.
I respect what you guys can do immensely.
Zivic
3,505
38
117k is nothing. those are great cars. run for many many many miles. my brother had a 2000 or 2001 model yr he sold on at like 275k. lady crashed it a couple yrs later at 350+. she called him up wanted to know if he had another after the accident..... I know they did little to no maintenance
ibex333
4,094
123
Thanks so much to everyone who responded. I agreed to buy the car. It feels very nice despite some minor cosmetic wear inside and outside. Nothing that cant be ignored or fixed for relatively cheap.
Question for those who know:
I saw some talk online regarding the timing belt needing to be replaced every 70k miles. I know for a fact the belt was never replaced. I don't want to just go to a mechanic and say "replace my belt because it needs to be changed every 70k". What are the signs when this belt is going bad if any? How do I tell?
Should I just get it replaced blindly anyway?
pauldun170
9,509
5,731
It may not be the popular opinion but when in doubt, assume the worst.
Change the belt.
Feb 25, 2011
16,994
1,622
Actually getting eyes on the belt is almost as much work as replacing it. So I'd just replace it as a preventative measure. You don't want that thing snapping.
bruceb
8,874
111
Replace the timing belt, do a coolant system flush with new hoses, T-stat and radiator cap, new coolant. Maybe toss in new spark plugs while you are at it and a new Cabin Air Filer. Have the brakes (esp rotors) checked for excessive wear. Same for steering linkage, ball joints, shocks. And you may need starter or alternator around 150K or so ... Those you can change yourself, if you can see them they are a DIY job
ponyo
19,688
2,811
You want to replace the timing belt. And I would also replace the water pump while you're getting the timing belt replaced. It should cost you little over $1k to get both done. And I would take it to the Toyota or Lexus dealer to insure OEM parts.
bruceb
8,874
111
Good call on the water pump. I forgot that has to come off to do the timing belt. Should also do a new serpentine belt and tensioners & idler pulleys as well.
DVad3r
5,340
They are good cars. I'm driving a 2001 Lexus ES300 with 360,000 km on it now. Only real issue was my tranny burning up but that's because I didn't change the fluid.
Definitely change tranny fluid every 30-40 k miles. Drain and fill.
ElFenix
102,402
8,574
considering that you can rotate the tires with nothing more than what comes with the car (assuming there's a spare), that's still a special setup. :D
