imported_intercollector
K,
We have a simple file server that we run at work that has an old TNT AGP card (totally not sure what flavour but it doesn't matter). Anyways, the card has a very basic HSF setup. A small thin heatsink with a fan screwed on the top. The fan started making terrible noises, so I found an old fan that's exactly the same size and threw it on. Unfortunately, the screws didn't fit perfectly, so the fan is sitting about 1/4 of an inch off of the heatsink.
Obviously we're not going to be running any 3D apps as it's just a file server, but it is important that the server stays up and doesn't have any down time for replacing video cards, fans, etc. I know that a lot of those basic cards come with passive heatsinks and run just fine. Do you think that having the fan sit a tiny bit away from the heatsink will cause any problems?
