Old system - best move for $100-$150?
guidinggod
Have an old Core i3-540 build on an Intel DH55HC m/b - has a Corsair VX550 PSU, 8 gigs of RAM and GTX 460.
My thought was if I could pop in a relatively cheap GPU, like a GTX 750 or 750Ti for around $120-$140, it would be enough for my cuz to play games like Bioshock, Assassins Black Flag etc for the time being. (connected to a 1080p monitor) and for general pc use.
Before I do, I wanted to confirm the following:
- Keep the 460 and change m/b and processor instead?
- (I think) that m/b has a PCI-E 2 x16 slot - that doesn't present a problem with these newer PCI 3 x16 gpu's?
- This old system and its psu have been running wonderfully via a solid UPS for about some years now, everything works well but the PSU is close to end of warranty (maybe another 5/6 months). Change the PSU and keep the rest for now?
I think I would do something like this. A 460 isn't the fastest GPU anymore, but it's no slouch. Here's a Bioshock Infinite benchmark. (Not sure if you meant the original, but it can't be harder.) A GTS 450 almost gets 30FPS average, so a 460 ought to do well enough. A 750ti is only about equal to a GTX 470.
Personally, I'd look for a cheap LGA1156 i5 or i7 on eBay and stick it in the existing mobo. If you have money left over, replacing the PSU is a good idea too.
PCIe is backward and forward compatible, so don't worry about that.
TBH, my understanding is that going from a GTX460 (is it the 1GB version?) to a 750ti is mostly a side-grade as far as raw performance goes. (Though it would certainly be more power efficient.)
Everybody is waiting for the GTX960 to be released, but the <bleeps> at Nvidia seem to think that they can extract more money from their customers (for a 970 or 980) by withholding the 960 until Jan.
Yes. That, or a used better CPU for the socket. If you're up for overclocking, a reasonably priced i5 quad, used/NOS, would be excellent. Else, a new i3, but what would kill your budget, most days.
The 750 Ti will be a minor upgrade from the GTX 460, except in terms of noise, depending on model. Unless you really are starved for VRAM (and got a 2GB 750 Ti), it wouldn't be worth it. Aside from piss poor texture details, a GTX 460 can still at least make any game today playable.
<- using a GTX 460 (again) with a Haswell
Get a good Antec or Corsair, when they get rebates, again. If you keep watch, you can get a RM650 or better for <$50 net, sometimes, and can pretty much always get a CX500 for <=$30..
@ dave_the_nerd, yes (my mistake, should have mentioned in the first post) - has an old Kingston ssd (would an ssd change to something newer be worthwhile, even though the m/b has Sata 2 only, not Sata 3?)
Going by the general consensus here, an i5-750 on ebay from a reliable seller about $70 and maybe a Corsair CX500M for $35
That 460 (1gb) is a workhorse but yea it does run loud, though I suppose the kid wont care much about that with his headphones on
That's not quite true, people tend to view the GTX 460 with rose-tinted glasses. The GTX 750 Ti trades blows with the GTX 480, which is quite a lot faster than a GTX 460.
Businesses exist to make money. If you have a $350 part that is selling out as fast as you could make it, why would you switch manufacturing to a lower profit part? That just doesn't make sense.
Nah. If you already have an SSD, just do the CPU/GPU upgrade like everybody else is saying.
The PSU could probably stand replacement, but it was one of their good ones, IIRC, so don't bother paying anywhere close to full price for a new one for an old PC (and, Antec and Corsair tend to have rebate deals often, on pretty good PSUs, so just keep a watch on them, and actually do the rebate). An i5-750, even left stock, will be a hefty upgrade, and make a lot of difference in newer games. The 1st-gen i3s' weird upgraded northbridge extra chip for the memory controller crippled them quite a bit, when it came to multitasking, newer multithreaded games, etc..
P.S. saw this, also:
http://www.ebay.com/itm/Intel-Core-...156-/221586058235?pt=CPUs&hash=item33978eebfb
2.8 v. 2.66GHz
Thanks for the suggestions - ordering a core i5 off Ebay (One of the links suggested above says it comes with no cooler etc, only cpu - current i3 stock cooler can be used though for i5 also, yes?)
Taking mfenn's point, going to keep the psu for now
Better to hold off on GPU for a few weeks in the hope that maybe a Black Friday deal or something shows up that would make it better (or is that just unrealistic/greedy? 🙂
The cooler you have on the i3 should be fine for the i5, there's only a 20W TDP difference between the Clarkdale and Lynnfield chips.
