- Jun 30, 2004
- 16,693
- 2,071
- 126
First, I just caught this thread -- which is fairly recent:
Win 7 and older Dot Matrix . . . etc. etc.
This has been a major let-down for me. I splurged on this HP DeskJet 1000C sometime around 1995 or 1996. It's been a great inkjet printer, but especially, it prints 11x17 and even larger pages -- in foldable "tabloid" format if you want.
It had been connected to a Win 2000 server; occasionally used with an XP system. Then, I had it hooked up to a D-Link DP-300U print-server box. With the latter, it was a nuisance only because I could never get it to print multiple copies.
Finally, I decided to replace the Win2KPro server-box with a WHS server (still not installed). [I think I'm losing my grip in old-age, because I'm getting behind in my projects -- and procrastinate.]
Because the WHS had not been installed (but Win 7 64-bit HAD been set up on the intended WHS machine), and because I needed the printer for a newsletter project I'm doing in some volunteer work, I decided to hold off on the WHS installation and hook the printer up to a PCI LPT port configured on a VISTA 64 workstation.
With the latter, I couldn't get the 1000C to print a test page, and I'd have to reset the printer. Thinking the problem might be the LAVA PCI LPT port, I connected the 1000C to the planned WHS box (with Win 7 64-bit) -- which has its own LPT port.
NO CIGAR!! NADA!
It will be a terrible inconvenience to move this printer upstairs and connect it to an old XP-Pro system in a room where there's hardly any space for such a printer.
I'm wondering if it isn't time to chuck the HP 1000C and buy a USB printer capable of 11x17 page printing.
I'm also wondering, since it looks more promising that 32-bit drivers for Win 2003 work with this printer (from things I've read in forums) -- that my luck may improve once I've installed WHS.
Anybody else?
NO CIGAR!! NADA!
Anybody else?
