I want to buy a k6-2+ and do some major o/cing on it. What would be the best cooler for this puppy? Willing ot spend about 30 bucks. Are the GlobalWin ones any good?
O/Cing a K6-2+? That's a no-no. At least, I'm about to own the same setup that you're talking about (with the Globalwin FOP 32 on a K6-2 550) and don't plan on o/cing it because I"ll only be able to get 570 or so (which isn't worth it for the risk).
K6-2+ will use a 0.18 manufacturing process (instead of 0.25 of the regular K6-2) so they must overclock better.At www.tomshardware.com they overclocked a 500MHz K6-2+ at 600MHz at 2.1 Volts.
Descend492 you only expect to get the cpu to 570? I guess you haven't read much on the k6-2 550 o/cing? On the Amdzone bbs many people got that at 600 easily.
Well, I can't change the bus speed because I have too many sensitive cards (a TV tuner and a very expensive sound recording input card), so that limits my max CPU speed
