okay what am i doing wrong with my oc?
theangel24
112
Hey all, hopefully someone can help me or at least explain to me some problems i'm having with my ram overclocks.
Asus 680i mobo with an e6600
I currently have a 2x1gb Super Talent T800UX2GC4 DDR2-800 rated at 4-4-3-8 2.2v.
I can't get the damn thing to boot into windows at those timings on 1T at 2.35v. i tried 2.2v and it still didin't do anything.
in fact i can't get it to go into 1T at all!!
I've read that 1T is the way to go with 680is but i can't get it to boot with NO OC at the reported speeds.
Is this normal or did I get some really bad ram?
Also, inside the bios my cpu temp is being reported at 80 celsius, and coretemp reports it at tjunction 80 cpu 0 35 and cpu 1 35. should i be worried that it's at 80 or is this normal and i should rely on the individuals?
nippyjun
8,447
I believe that you are supposed to use 2t.
And as far as your temps go , get intel's thermal analysis tool (TAT) to get accurate core temps.
Tjunction is the max temp that your cpu is supposed to reach before idling. I bet that coretemp is more accurate then your bios reading. .. but get TAT just to check. If it is running at 80 that is too hot.
theangel24
112
wha... so i can't go into 1t mode at all?? :( I've read people setting their rams to 1t all the time.... i should've gone with ocz :(
i can't get intel tat to work. i installed it, but i get some funky error when i run it.
