okay, so... what exactly does a "controller card" do?!
NikPreviousAcct
52,763
Is a "hard disk controller" essential for a PC to run? I thought it was, but I'm just asking.
Okay, so what the hell does this stupid thing do? What's the point?
Are there any motherboards with it built in?
thanks!
Dark4ng3l
5,061
Probably an ide controller card witch controls ide periferals like hard drives and cd roms, cd rw, etc.
ArchAngel777
5,223
61
No it is not essential, but you wont have an OS :p HAHAHAHAH, ok yes it is very nessecary. without that you have no hardrive because nothing can control it!
~THE END~
RossGr
3,383
Pretty much all modern MoBos have built in hard disk controllers (The IDE ports). No they are not necessary for a computer to run, They are only needed if you want a hard dirve. I am sure that you could set up dual floppy DOS system if you really wanted to. It may be hard to find software which would run on it (forget about Windows). My first PCs (in '80 a Apple II+, then 8086 PC in '86) were both dual floppy systems, no hard dirve. The application disk went into drive A and a Data disk in drive B. YOu could even run your system with no foppys, but why?
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Basically a HDD controller card unloads the task of controlling HDD's from the system board. Most controller cards have faster controllers than those integrated into less expensive system boards, some controller cards also allow for more than two IDE channels. Quite a few IDE controller cards also include a parallel port and/or a serial or gameport. Yes, most (all?) new system boards integrate an IDE or SCSI controller, and so a controller card is not necessary for newer computers. So, technically, a "controller" is necessary, but a "controller card" is not, because most system boards have the controller built in and do not need an add-in card to do that work.
Zenmervolt
