I think I have found a good package to put together to upgrade my computer.
I am looking at the following:
- AMD 1600+/266 FSB Athlon XP PROCESSOR CPU - OEM Athlon XP 1600+/ 1.40GHz, AX1600DMT3C. The AMD Athlon XP processor with QuantiSpeed architecture powers the next generation in computing platforms, delivering extra performance for cutting-edge applications and an extraordinary computing experience
- EPOX EP-8K7A AMD-761 + VIA 686B AGPset MOTHERBOARD For AMD & AMD XP - RETAIL. UltraDMA-100. 200/266MHz FSB. 2 DDR-SDRAM(PC266). 6 PCI, 1 AGP. Built-in AC97 Audio. ATX.
- Crucial Micron 256 mb 32x64 pc2100 DDR ram OEM
- Thermaltake VOLCANO 6Cu. Heatsink + Dual Ball-Bearing Fan, FAN Speed: 4550±10% RPM. Max. Air Flow: 32CFM. Pure Copper base & contact face. Interface Material: Bergquist 225U. Dimensions: 80x60x65 mm. (* According to Manufacturer, This fan is designed for AMD ATHLON 1.9GHz+, INTEL PIII 1.13GHz & TUALATIN, up to 2.0GHz.*)
This is from newegg.com .Does this sound like a good package?
It looks like I will need a new power supply also.What wattage should I get for this combo and made by who or which model?
Thanks.
Thanks.
