OKAY CS GUYS!!! I NEED YOUR HELP... again...
hpkeeper
4,036
I install the 80 some-odd megabyte file to upgrade halflife to counterstrike... alright... I get into counterstrike and I say I want to play a new game and it says it can't find a file named:
cstrike\cl_dlls\client.dll
what is with this file? is that something I need or something? please help!!! The suspense to play this game is unreal!!! ERG!!!
ThE KeEp
stonythug
Banned
Nov 1, 2000
460
I don't know, I have it though. If you want me to send it to you somehow, or upload it somewhere I can. I don't know why you wouldn't have it though, that seems kindof odd. I wonder if once you get this one, it's just going to ask for another dll file. Sounds like it wasn't installed properly or something.
hpkeeper
4,036
okay... something wierder just happened... I moved the file into the directory and it says "Do you want to replace this 588k file with this 588k file" blah blah blah the normal windows thing... wtf is up w/that???? it was already there!
nEoTeChMaN
When you're done....get your as$ over to NeoMadHouse.
24.163.83.40:27015
password: anandtech
AlphaIVT
Banned
Jul 26, 2000
3,650
its a prob with the install, you HAVE TO download it again, then install again ;);)
j/k, just uninstall, restart, install, restart, open, hope it works, tahts what my friend got
Pretender
Banned
Mar 14, 2000
7,192
You probably downloaded the wrong CS version. If it gives you a message about "different version of client.dll" or some other file when trying to play, that's the most likely cause. Look for (and download) counterstrike 1.0, not 7.1. The filename should be cs10.exe or something similar.
hpkeeper
4,036
yeah pretender, I got 1.0, I may just need the most recent updates for Half-life though... Gimme about an hour, cuz this is gonna take a while...
