- Apr 11, 2000
- 6,019
- 25
- 86
Quick synopsis.
Purchased a 120gb Maxtor HDD from a trader in the FS/FT forums. Installed XP with no problems on the drive, but screwed up a restore attempt (had multiple drives in the machine, put files on the wrong drive). I figured it was no problem, I'd just format and re-install XP. Only problem is, my Dell 4550 will no longer detect the hard drive as master. If I use another hard drive as a master, it shows up as a slave. Otherwise, my machine won't detect the drive at all.
I'm 100% certain the hard drive is not faulty. It detects as a master on another (home built) machine.
So wth is going on with the hard drive? I formatted it using MaxBlast 3 software. I ran the error checking utility under XP (with the drive as a slave).
I also used the Maxblast 3 software to do a quick zero write (first 63 sectors or whatever). Would a full zero re-write (a low level format as I understand it) fix my problem?
Also wanted to add that I replaced the IDE cable, that is not the issue.
