ok wtf is wrong with my dvdrw drive?
Tret
I have a Nec 3500-ag everything was working perfect...until I restarted my computer and now my computer is showing up now as a removable harddisk I'm running windows xp sp2. I enabled Extended System Configuration Data then everything worked again....then restarted again and now it's back to the removable harddisk again. I checked disk management and it's not there. Then I checked device manager and it's under the disk drive. Should I uninstall it from device manager and then install it again?....What should I do?
did you try uninstalling the drive and reinstalling in dev. manager? how about unplugging and plugging it back into the ide cable? can you try a restore point? how about a xp repair, not reinstall but repair? just trying to help i have no idear.
Originally posted by: w00t
uninstall and reinstall. maybe go to the website for the latest drivers
I uninstalled and installed it but it appears as a removable harddisk again. The drivers can't find the dvd rom.
I'm going to disable my extra harddrive since it's set as a slave restart uninstall restart see if it shows as a dvd rom again.
It showed up as a dvd rom after I restarted installed the new drivers for the dvd rom enabled my other hd and then POS windows starts up it's found new hardware and changes my dvd rom into a disk drive!!!!!!!!
Is their a way to disable the found new hardware pos?
Originally posted by: bacillus
hmm, by any chance have you been using an external hard drive or USB flash memory before this happened?
no
why is that when i build a computer for someone else it runs smooth as glass....but, when the computer is for me I always end up getting problems god hates me 🙁
