Ok, what in the world is wrong with my system?
Discussion in '*nix Software' started by Red Squirrel, Jan 26, 2013.
  1. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Just tried a different approach: 3 separate X screens. One for each monitor.
    What I wanted to do is have monitor 1 and 3 as one session, with the main one in the middle, but it would not let me orient it that way. So to be able to have the cursor move across all 3 I had to go with 3 separate, not a huge issue I guess. BANG, that stupid black theme thing came back again when I restarted. Definitely does not like the separate X sessions. Going to leave it overnight to see if I get those blocks and crap too, and if the stuck cursor thing starts happening again. I have a feeling the stuck cursor thing wont, but the blocks will, but we'll see.
    Also realized I never posted a screenshot of that weird theme, this is what it looks like:
    [​IMG]
    This is what it's suppose to look like:
    [​IMG]
    If I pick another theme, it will basically do the same thing, but with the "look" of that theme. The title bar goes black and text goes black.
    When this happens, it only does it on the main screen.
  2. Jodell88
    Jodell88 Diamond Member
    Jan 29, 2007
    9,492
    29
    The fact that it is the window decorations exhibiting this issue means that it lies with the window manager (XFWM4).
  3. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    46,331
    528
    Is the black the Adwaita theme? I had issues with Compiz, and it using the GTK3 theming. I changed it to something more palatable, but it's still squirrelly. I haven't put a lot of attention in it, because I really only use to make my desktop snow in the winter, and have leaves fall in the autumn. I can deal with ugly window decorations for a short period of time.
  4. Jodell88
    Jan 29, 2007
    9,492
    29
    The theme he's using is greybird, the default theme for Xubuntu.
  5. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    46,331
    528
    The black isn't greybird. It doesn't have the ginormous window controls of Adwaita, but I don't know why it would be black.
  6. Jodell88
    Jan 29, 2007
    9,492
    29
    It's greybird but it's bugged somewhere. I'm thinking it's the window manager.
  7. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    46,331
    528
    Maybe he could try running Compiz instead, and see if that works better.
  8. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Using "default" (one selected in screenshot) but if I select any other theme, the same thing happens to it too. Basically the title bar of whatever theme I'm using will go all screwy, and other elements mess up too, but the title bar is the first thing I usually notice. It will also do that on only the main screen and not the other two, at least from what I noticed.
  9. Jodell88
    Jan 29, 2007
    9,492
    29
    That's why I said that the problem seems to be the window manager.
  10. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    How would I go about fixing that? What exactly is the window manager? Is that like "Explorer" in Windows? So like, Thonar? Is there an easy way to switch to another one?
    Also, I did not get the stuck cursor or the blocks yet, though it's still early to tell, but assuming this works out with the 3 separate X sessions, is there a way to make it so I can have multiple instances of a program open? Ex: if I have Firefox open on one screen it wont let me open it on the other because it's already running on the main.
  11. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    46,331
    528
    It handles compositing eg drawing window decorations, handling window placement, and creating special effects.
    I'm reluctant to give you advice, cause you setup is weird, and I don't really know this stuff. I just change things and see what happens. I'd try using Compiz, but you might have to change your whole setup. Your extra X sessions might break, and configuring things will be different. OTOH, it might be easier to setup.
    If you want to do that, install compiz and related packages. The screenie below is what I have installed. Some are just superfluous addons, but that'll give you compiz and the control panel for tweaking settings. To use it open a terminal and type compiz --replace. your scree will flash, and you'll be using compiz. Close your terminal, and adjust your settings using the control panel. You can add and remove plugins to get different features. If it doesn't work, or you don't like it, open your terminal again, and type xfwm4 --replace.
    [​IMG]
  12. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Cool I thought Compiz did not work for XFCE for some reason, pretty sure I read that somewhere but may have missread. I actually originally wanted to use it. Installed and it's initializing now after I typed that command. Lost all the title bars which I guess is normal. How long does this usually take?
    Also silly question but what's the difference between the synaptic package manager and the ubuntu software centre? I tend to use ubuntu software centre for stuff. Should I be using the synaptic one instead?
  13. Jodell88
    Jan 29, 2007
    9,492
    29
    The software center is for n00bs.
    You might want to open the compiz control center (ccsm?) and enable title bars and the like.
  14. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Oh so I should not bother with software centre? I actually forgot about Synaptic till it was mentioned since software center is what is in the main top bar by default. I can always change that.
    The compiz process is not done, so I think the reason I have no title bars is because of that. Just wondering if it's normal for it to take this long.
    Code:
    ryan@falcon:~$ su -
    Password:
    root@falcon:~# compiz
    compiz            compiz-decorator
    root@falcon:~# compiz --replace
    Backend     : ini
    Integration : true
    Profile     : default
    Adding plugins
    Initializing core options...done
    Been sitting here for a while. If it's normal I'll wait, but I'm starting to wonder if it's not, now.
  15. Jodell88
    Jan 29, 2007
    9,492
    29
    https://wiki.archlinux.org/index.php/Compiz#Initial_configuration
  16. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    After playing around with this for a while I lost my keyboard several times and had to hit the power button. Ended up being able to run it under my own user and it sorta works except it seizes a console window for it to work. Is there a way to just make this my default window manager across the board? it's also only doing it to the one X session. Would be nice if I can have 3 monitors working normally like it would in Windows but that's a whole other battle.
    Also get a bunch of errors, if it means anything.
    Code:
    ryan@falcon:~$ compiz --replace
    Backend     : ini
    Integration : true
    Profile     : default
    Adding plugins
    Initializing composite options...done
    Initializing opengl options...done
    Initializing decor options...done
    Initializing move options...done
    Initializing snap options...done
    Initializing resize options...done
    Initializing scale options...done
    Initializing put options...done
    Initializing place options...done
    Couldn't find a perfect decorator match; trying all decorators
    Starting gtk-window-decorator
    Window manager warning: Failed to load theme "Adwaita": Failed to find a valid file for theme Adwaita
    compiz (decor) - Warn: No default decoration found, placement will not be correct
  17. Jodell88
    Jan 29, 2007
    9,492
    29
    look in the link i posted
  18. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    None of the files it talks about exist on my system. Ex: ~/.config, /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-session.xml, etc..... Do I just create them? How do I know anything is even looking for them? Or since I'm not using ArchLinux, maybe they're located elsewhere?
  19. lxskllr
    lxskllr Lifer
    Nov 30, 2004
    46,331
    528
    What happens if you just close the console?
  20. Jodell88
    Jan 29, 2007
    9,492
    29
    There should be a ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-session.xml since this is default behaviour.
  21. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    edit: NM, I think I see it, it was not auto completing for some reason so I thought it did not exist but if I type it fully or do dir it's there.
    #71 Red Squirrel, Feb 27, 2013
  22. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Getting somewhere, I think.
    I got the settings to stick, had to reboot a few times but it looks like I'm now using Compiz.
    Only thing, the title bars are only showing up on the primary monitor. Is there a setting somewhere for this, maybe I have to do something for each X session?
    Couple other things but I'll play around with it, have to go for now. Also, does this get rid of xfwm4? That's one of the apps that constantly crashes, did not realize that had to do with the window manager, maybe if this app wont be used anymore, I wont get as many random crash alerts anymore. Kill two birds with one stone, perhaps. Maybe that's why the windows were acting up.
  23. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Well this morning I go to use the computer. Screens are off and wont respond. Had to hit reset. Come back, sure enough, now it's Compiz that crashed! Before it used to be xfwm4 that crashed all the time.
    I'm going to try my original idea of using synergy and another tower to control the two other monitors, and keep 1 monitor on the primary machine. If that does not work think I'll just go back to windows 7. It had it's issues too, mostly the screens randomly shutting off for 10-20 seconds followed by a driver crash, but other than that it was fairly stable. I just hate how windows handles multi monitor in the sense that it opens stuff wherever it wants, instead of on the same screen as the cursor, but at least it works.
    Seems it works fine with just 1 screen but as soon as I add more that's where things get flaky.
    #73 Red Squirrel, Feb 28, 2013
  24. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Played with Synergy a bit with my old XP machine and it was surprisingly easy to setup. Though I still need to look at getting it to work with the machine having 2 monitors and the main being in the middle but from what I read online it seems to be doable.
    If this works I'll try to find/build a small form factor PC and shove it under my desk, and I might be good to go. At least to some extent, I was still having issues with 2 monitors so hopefully I don't get those on the secondary PC...
  25. Red Squirrel
    Red Squirrel Lifer
    40,811
    1,249
    Well the cursor thing happened again, with just one configured monitor. So far it seems to always happen when I click a link in an email. But it's happened in other situations too.
    This time was a bit different, the new window it opened only half drawn. Usually it would still open and the GUI was still working, it's just that with no keyboard and a cursor that can't click, I could not do anything but hit the power button, which does a proper shut down.
