OK to safely remove hardware? WD SATAII 320GB issue
May 31, 2000
75
I just built a computer for someone using a western digital 320gb SATAII drive on an Epox nForce4 ultra mainboard. After installing the forceware drivers I get a system tray icon telling me it's ok to safely remove my SATA hard disk.
1. Why is this icon popping up?
2. How can I make it go away?
This is the first computer I've built with an SATA drive so forgive my newb-ness.
I am using WinXP pro SP1a on this computer.
iRONic
8,194
3,515
1. The drive is hot-swapable.
2. You can only hide it. Start>Settings>Taskbar and Start Menu. Tick the "Hide inactive icons" box. Click apply.
evilsaint
1,364
[/quote]
2. You can only hide it. Start>Settings>Taskbar and Start Menu. Tick the "Hide inactive icons" box. Click apply.[/quote]
QFT. Just installed a SATA drive myself, and that little extra icon has been driving me nuts too. Maybe M$ will allow enough flexibility to hide *just* that icon (or it's equivalent) in Vista, but for now, you're SOL, unless you don't mind the other icons being hidden too.
jmdeathsquad
643
I have almost the same mobo and I've never seen that icon, I have wd 250 sataII... it must be hot swappable as iRONic said.. though probably not a good idea if its your OS drive ;)
elecrzy
184
well, if you configured your mb(options ihe bios are: ahci(full sata), ide, raid) to treat your sata hds as ide hds, then you won't be able to use the SATA features such as NCQ, hot-swap, etc.
DBSX
206
[/quote]
I am not sure what "M$" is... maybe you meant "MS"? Regardless, why do you need to wait for Vista to do this? I can do it with Windows XP. Right click taskbar --> Properties --> Hide In active icons button --> customize to your hearts content (click "Always hide" for the add/remove hardware icon and Always show for any you don't want hidden). Simple. Flexible.
\Dan
