otispunkmeyer
ok
Problem: my second computer (in sig) has a daft problem. every other boot up (say all the odd number boot ups) the sound will not boot (audigy card) and the network card ( a D-link job) wont boot either. so im left in windows with no sound and no LAN
however, this computer also has a thermal take thermo electric cooling system. you may know the one im on about. it has a huge chunky controller/power PCI card and the whole thing has to be plugged into the mains to work. the pci connection on this is mainly solid plastic but there are a few traces on it. it has a blue status light, when it flashes somethings up. this light flashing also coincides with the sound and netowrk not working too
now the PSU in this thing is a Q-Tec 400watt psu. now the computer had been running fine with a 9700pro in it, my friend sold me this computer and ive put my 9500Pro in it. and its giving me this problem.
i was cleaning the rig today, and i read the spec on the PSU. its rated for on the 12v rail 16A Peak, 12A max
is that too low for this?
P4 2.4Ghz, 768Mb PC800 RDRAM, Gigabyte P4 Titan mobo intel 850i chipset. a single WD 80Gig drive. 2 CD drives, 80mm and 120mm case fan, a 9500Pro, and a small exhaust fan in a pci bracket
thermo electric cooling is externally powered.
in short
sound, and network fail to work EVER OTHER BOOT UP
the externally powered thermal take thermo electric cooling also says it has a problem when the LED either flashes or goes out. this happens every other boot up at the same time as the other two.
in short
