OK, I'm about to build this system from newegg, need a little help
Reebdoog
78
This will be my first custom system, I just need to know if I need to buy any cables, accessories, etc to put it together.
Pro Source ULTRA COOL Full Tower ICEBURG Aluminum Case With Side Window Model
$65.00
CD/DVD ROM Drives
SONY DDU1621(DDU1611) 16X DVD ROM Drive (40X CD-ROM Speed) - OEM
$40.00
CPU Thermal Paste / Grease
OCZ Ultra 2 Thermal paste Retail
$6.99
Fans, Heatsinks (Case, CPU, Chipset)
COOLERMASTER DP5-7JD1B-0L CPU FAN SOCKET A/370 CPU
$17.00
Memory (System Memory)
KINGSTON KVR400X64C3/512 512MB 400MHz DDR PC3200 DIMM RAM CL3
$76.00
Motherboards - AMD
Asus Motherboard for AMD Athlon/XP/Duron Processors, Model# A7N8X (support AMD XP2800)
$69.00
Processors
AMD Athlon XP 2100+/266 FSB Thoroughbred Processor CPU 2100+/ 1.73GHz -OEM, AXDA2100DUT3C
$75.00
Speakers
Altec Lansing ATP3W 2.1 Speaker System - OEM Delivers powerful audio output in a space saving design.
$53.00
Video Cards
Sapphire ATI OEM RADEON 9500 128MB DDR BULK
HumbleFish
390
Hi Reebdoog,
The IDE Hard Drive and Floppy cables should come with the motherboard, and there should be cables with the DVD and CD Drives... I would say that You don't need to buy any cables.
However, you didn't mention whether you have a Power Supply with your case?
vaporize
194
where did you find this stuff?
17 bucks for 512 mb pc3200 kingston ram?
53 dollars for 128 mb radeon 9500?
$76 for ASUS A7N8X?
DAPUNISHER
32,121
32,697
where's the hard drive? Gonna use a Floppy? Aready have a keyboard and mouse? I take it you have an O.S. to go on there already as well?
Apr 17, 2003
37,622
the ram is pc3200 so it's not bad, but i would spend a little more and get XMS or something of the like that can do Cas 2
Reebdoog
78
alright I added the ram, it was a great suggestion, heres my setup now.
CHIEFTEC Server Chasis (Aluminum Workstation Tower with Plastic Front Cover) Blue w/acrylic window **Now with 2 x Front USB2.0 and 1 x Firewire IEEE1394 ports $82
SONY DDU1621(DDU1611) 16X DVD ROM Drive (40X CD-ROM Speed) - OEM $40
OCZ Ultra 2 Thermal paste Retail $7
COOLERMASTER DP5-7JD1B-0L CPU FAN SOCKET A/370 CPU $17
MAXTOR 60GB 7200RPM EIDE HARD DRIVE MODEL # 6Y060L0 - OEM, DRIVE ONLY $80
CORSAIR MEMORY XMS Extreme Memory Speed Series 512MB 32MX8 PC-3200C2 With Heat Spreader $108
Asus Motherboard for AMD Athlon/XP/Duron Processors, Model# A7N8X Deluxe Retail $130
AMD Athlon XP 2100+/266 FSB Thoroughbred Processor CPU 2100+/ 1.73GHz -OEM, $75
Altec Lansing ATP3W 2.1 Speaker System - OEM $53
623.48 bucks
Chobits
230
I have those speakers and my friend they are NOT worth 75 dollars. You are better off with the Logitech Z650s (or 560s? Who know :p). They ARE worth the 29.99 I paid for them on Black Friday but I truly beleive that they are not worth the price you are goint to pay
Also I'm assuming you already have the other parts that are not listed, but plunk the extra 18ish dollars and get the 80 gig Western Digital SE with the 8 meg buffer...
Reebdoog
78
I'm not getting a gfx card for now, it will have to wait because I dont have the money, plus I head the A7N8X has very good onboard.
Chobits, I'll take your advice on the speakers and HD. thanks
Anyone know which fan I should get?
ScrapSilicon
13,625
A7N8X has no onboard video
nick1985
27,153
lol
