I purposely left a cae out of my budget in building my new computer so I could make my own, but now I don't have an on switch. Tell me there's a way around that 😱
There is.
Basically, on the mobo there's a little patch of connections, which are for the power LED, reset switch, HDD LED, system speaker and power switch.
If you work out which 2 pins are for the switch, then you can make your own power switch and LED's and just hook them up to the motherboard.
The other option is to buy a cheap ($5) case and just rip all the power/LED/etc cables out of it and use them in your own case.
Pic
2 of those pins are for the power on switch. Then there's all the other switches as well.
The motherboard manual will have the pin configuration.
hell just go to radio shack and spend a couple bucks on a momentary switch, that is what i did for my test bench.....push it and let go....system turns on🙂
