Ok Guys, I screwed up HELP!!! (computer problem)
neomits
3,228
Alright. Long story short, I screwed around using registry hack with explorer.exe and now it won't run. It won't startup when I bootup and when I try to run it through Windows Task Manager it says that its not a valid Win32 application. I've already tried repairing off the WinXP ( Oh yeah this is in WinXP) disc and I've tried to system restore and no such luck. Like I said I can run Windows Task Manager so I can run most of my programs.
PLEASE HELP!!!!!!!!!
Rent
7,127
<< I messed up explorer >>
If you've tried system restore from the CD, I'm afraid your out of luck... maybe somone else knows.
Mangos
536
Run sfc /scannow
It checks all of your files to make sure that they're valid (original).
It will ask for your WinXP CD to repair non-valid files.
TallBill
46,044
62
damn mangos.. u beat me.. i just had to do that with a win98 install and it worked great.
neomits
3,228
nope that didn't work
JUST FORMAT IT!?!?!? what!?!?! right format my 60 GIG drive that has tons of stuff I want to keep on it. No thanks
any other ideas.
this is the explorer.exe file not the registry
Thanks for all your help
SagaLore
24,037
20
<< nope that didn't work
any other ideas.
Copy the explorer.exe file from another computer or CD and paste into the directory it's supposed to be in.
And next time don't play with the registry.
Derango
3,113
Situations like this are why you should keep the OS on a seperate partition from your data ;)
Nemesis77
7,329
Not to sound like a smartass but... this is a perfect example why you should make a small C:partition and put the OS there, and put everything else on separate partitions. In case you need to reformat and re-install your OS, you don't lose any other data but your OS.
EDIT: Damn! Derango beat me to it :)!
iamwiz82
30,756
4
i do the same, 'cept i go one step further. I partition 3 my HDDs into 3. OS, installation folders, and everything else.
ASK THE COMMUNITY
