Apparently, I'm just not understanding how to use this. I've read that offset is better than a set voltage, which I get because it should theoretically drop the voltage when not in load. So, how do I use it? I tried switching to offset and it showed my VCore to be at 1.224 so I put it at -.035 assuming that's how much it would drop at idle. I also have speedstep on allowing it to drop the multiplier when idle. Am I doing this right? Cause Win7 wouldn't boot so I went back to manual. Also, can anyone explain to me what C1/3/6 is? Should they be on or off?
