so, I've changed my mind from the 2405 and will be getting the Samsung 244T.
I have a question. I have 4 PC's tied through a KVM switch. The switch can handle up to 1920x1440, so native is no problem through it.
From a video card perspective, 3 of the 4 will be fine at native res. My laptop is a bout 3 years old(work pc), and can only display as high as 1600x1200.
So, when I hot-key on the KVM from one of the 3 PC's running at 1920x1200, and hit the laptop at 1600x1200, will the LCD automatically just adjust to display at this res. and will it look OK? I assume there will be vertical bars on each side of the display, but I just want to ensure as you move between PC's on an LCD with different resolutions, you don't have to manually change anything on the LCD.
thanks!
thanks!
