Oily Nose...
efript
ok my nose is constantly oily... i mean i wash my face and 30 minutes later its oily.... whats going on?
are you between the ages of 12-28 ?
if so, wait until you get older and it will dry out , a bit
Try some skin lotion for oily skin and stopping some many oily foods. I think you also need to get ripped... more 😛.
rofl im laughing so hard at the 'work out' and 'get ripped comments'. heh. ill never make multiple posts so close together, EVA!
The more you wash the oil away with soap, the more your glands will try and compensate by producing even more oil. Wash on a regular schedule and eat healthier.
don't u know what thats good for?
rub your nose then dip your thumb in the foam or your:beer: to get rid of foam.😀
Don't fret about it. It helps to keep raindrops from forming on your nose. Sorta like RainX for your car windshield. 🙂
If you've got any CDs that skip because of scratches, just rub some of the oil on them (seriously) and the problem is sometimes solved 😛
Never clean your nose with regular soap, it makes your pores bigger. I did it, now it looks like I have lotus seeds where my nose is. (shudders at boob pic with holes in them)
I use gentle foaming cleansers, ph balanced. Massage onto skin, gently rinse away.
