Oil light comes on when slowing from 60 mph
GasX
29,033
While doing some highway driving over the weekend in a fair bit of traffic, myy oil light came on a few times when I rapidly deccelerated. It went off after about 15 seconds. I figure that the braking resulted in a pressure drop that triggered the alarm. does this mean I might be a bit low or is it just par for the course?
2004 A6 if it matters...
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
The A6 has both an oil pressure light and an oil level light.
I'm willing to bet that the light you saw was the oil level light and not the oil pressure light. Check your oil level.
Also, if it indeed was the oil pressure light, then you really need to stop the engine immediately rather than continuing to drive the car. The only way that braking could trigger a pressure drop is if the oil was so low that the oil pump pick-up was un-covered and the engine was temporarily not getting any oil. It's also worth noting that the oil pressure light is a no pressure light and not a low-pressure light. If the oil pressure warning light comes on, it means you have essentially zero oil pressure.
I still think it was the oil level warning light in your case though. Check the level and add some oil.
ZV
Eli
Super Moderator | Elite Member
8
ZV
:thumbsup:
More than I would have said.
But in either case, you need to check your oil immediately.
I wish more manufacturers would include oil level lights. That would be handy.
Something like a yellow light at 1/2 a quart low and a red light at 1 quart low would be awesome.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
They do have those. They're called "dipsticks" and you check them at every other fill-up. :p Or maybe I'm just OCD. ;)
ZV
NuroMancer
1,684
<div class="FTQUOTE"><begin quote>Originally posted by: Eli
Something like a yellow light at 1/2 a quart low and a red light at 1 quart low would be awesome.</end quote></div>
ZV
Thats what works for me :)
Assimilator1
24,151
516
ZV
lol no you're not,your not kidding ,the number of cars I've seen come into the workshop with the oil off the dipstick beggers belief ,not to mention tyres being 1/2 flat!
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
I've only ever had a tire go half flat. The top part never gets flat, only the bottom part. They should make it so the top part goes flat and the bottom stays round. ;)
ZV
Eli
8
<div class="FTQUOTE"><begin quote>Originally posted by: Assimilator1
not to mention tyres being 1/2 flat!</end quote></div>
ZV
:laugh:
exdeath
13,679
10
Probably low oil and the weight transfer caused the oil to slosh away from the pickup and either trip the oil level sensor or starve the engine... this is why high performance cars use dry sump systems where the oil is scavenged into a reservoir instead of dumped to the oil pan for reuse, because it can't slosh around when braking and cornering.
Changing the oil *after* the oil pressure light comes on though, just a FYI, is a good way to destroy your engine and make your oil look like metallic nail polish.
Assimilator1
24,151
516
Changing the oil after the oil light comes on doesn't knacker the engine,its the oil starvation that damages the engine in the 1st place when the light came on.
ZV
lol:D
