absolutelyOriginally posted by: Linflas
The very first thing you should do is check the oil level.
Originally posted by: gotsmack
My oil light comes on when I break moderately-hard. I don't have time to get it fixed until Friday but if its serious I'll leave early tomorrow.
any ideas?
thanks in advance.
it's an 88 volvo 760 4- cyl turbo.
it doesn't leak. I'll get my breaks checked and the coolant flushed.
(2)Oil has not been changed frequently enough (3,000 miles intervals)
What do the breaks and coolant system have to do with your original question?
Hmm, I only change mine every 25,000 miles...
Bill
Originally posted by: yamahaXS
I think i will go post a new thread and ask a question, but I will make sure not to read any of hte replies so that my response leaves everyone wondering if I am crack.
Originally posted by: Roger
Possable causes;
(7)Contaminated oil (Water/coolant)
Yes, and you are probably running full synthetic.Hmm, I only change mine every 25,000 miles...
Bill
