Oil on the tip/electrode or oil on the top area around the insulator?
If the oil is from the top, its a valve cover gasket as Arkaign mentioned, if its on the spark plug tip, you may have internal engine problems (valve guides)
If there was oil inside the cylinder I would expect burnt crap all over that plug. If it's just on the threads it's probably flowing from the head down, not from the combustion chamber up. That's a good thing.
