Oil filter heat sink
cavemanmoron
13,664
28
What also does work is the magnets that you can buy
'that go on the outside of the filter.
Those heat sinks do work some,but,are not needed on a street driven car.
funboy6942
15,362
416
Id say about as good as thoes $100 tornadoes I seen :roll:
What a waste :p
Wait till the little berring inside it falls apart and your engine sucks in metal parts right into the combustion chamber. Oh yeah that wont cause any damage what so ever.
If you want to cool your oil off go buy a trans cooler for the same price and it will work tons better then that POS.
jagec
24,442
What a waste :p
um, it goes on the OUTSIDE of your oil filter...so it won't cause any damage. It is pretty worthless, though.
funboy6942
15,362
416
What a waste :p
DUH I was making the point that it just as worthless as the tornado :p
Just took it a little off track is all.
