It's your favorite neiborhood tech again, dont sue me.
The only reason that you change the oil in a car is because over time it will break down. A synthetic will break down VERY slowly. Organic oil, or STD oil, loses it's "slippryness" over tiem from thermal break down and from actually being cut in 1/2 by rotating parts. Synthetic is not harmed my "normal" operating temps, only by being cut up. If you have a car that is out of warantee, then you can go about 50,000 miles without changing the oil, bit you DO have to chage the filter. The filter takes out all the crap that gets in your oil ( casting samd, ash, ect ) and keeps it from harming your engine. A safe bet would be to chage your oil filter every 7-10k miles for reg driving, or every 3k for serous driving ( towing, off road, short trips, ect )
If it is in warantee, then no matter what, you have to chage it at the interval in your manual. Every vehicle is different. For example, here are some that I know.
Suzuki Sidekick 1.6 = 7500 miles
Dodge 2500 V-10 8.1 = 6000 Miles
S10 4.3 V6 = 10,000 miles
The only reason to change your oil in 3000 miles is if you do towing, short trips, snowplow, off roading, ect.
I am a tech at a dodge dealership, so I do know what I am talking about
