- May 22, 2001
- 344
- 0
- 0
I am in the middle of building a new computer for a friend. Everything is hooked up and I go to POST. Looks good but then says "Floppy Drive Fail (40)". I look at my floppy and did not see the light going on. I figured it was a power supply problem. I thought I might have plugged the 4 pin in the wrong way. I flipped it around and went to POST again. Next thing I know the wires for my power supply are on fire, smoke everywhere THICK!!!. I go to grab the wires and pull it out of the floppy, no good to hot, fire, think I even got shocked in the craziness. Then I pulled out the back power supply plug going into the case.
Okay after the smoke cleared the damage was the four pin wire going back to the next connector has no plastic coating left.
WHat did I do? What should I do now? PLEASE HELP.
Do you think anything else was damaged?
I have to send this computer across the United States and I wont be there to trouble shoot if anything goes wrong.
I hope I did not do any other damage.
I pulled the 4 pin back out of the floppy and did another POST.
Everything looks fine and it says "Floppy Drive Fail (40)" again like before.
