Ogg Vorbis noticeably better than MP3?
brxndxn
8,475
I downloaded a copy of Mr. Blue Sky by ELO (allofmp3.com) and I figured I'd try listening to the Ogg Vorbis format just for the hell of it. I had it encoded in 256kbps Ogg Vorbis and was amazed when I listened to it. I'm using a basic pair of Sennheiser headphones and my laptop to play it and it sounded clearer than any mp3 I've ever listened to.. and I've been growing tired of my huge mp3 connection because it just seems 'muffled' to me. The .ogg seemed to have much more pronounced highs and lows than 256kbps mp3.
Just to be sure, I downloaded the same song in 256kbps variable bitrate mp3 (lame) and it did not sound as good as the Ogg Vorbis one, imo. The mp3 seemed much less distinct in terms of lows and highs..
I'm very impressed with the Ogg Vorbis format..
Taejin
Moderator<br>Love & Relationships
Aug 29, 2004
3,270
in my experience, ogg is a superior format than mp3.
EDIT: This is coming from someone who was initially skeptical of ogg - which was pitched to me by someone who loves open source stuff because he thinks everything SHOULD BE OPEN SOURCE AND BOYCOTT WINDOWS AND OMG OPEN SOURCE!!!! FREE LOVE!!! (I especially hate that)
Taejin
Aug 29, 2004
3,270
Hah! I posted a fraction of a second on the same second as Coquito did! :p
Confused
14,166
IMO, yes, Ogg Vorbis is better than MP3
Take an Audio CD, and encode a track to the same bitrate MP3 (using the LAME codec as it's the best) and Ogg Vorbis, add both to Winamp, and shuffle them around randomly a few times (so you don't know which is which) and try to figure out which is Ogg and which is MP3.
I am able to tell the difference almost every time. Of course some tracks have less of a difference than the others.
Alternatively, if you want the best sound quality, use something like flac as it is lossless compression, so you lose no quality over a CD.
Gurck
Banned
Mar 16, 2004
12,963
Originally posted by: Mo0o
what about size differences?
As with mp3, ogg size is user-defined. At any given bitrate ogg sounds better imo, I rip most CDs to 192bit ogg (the rest - my favorites - to flac).
ed21x
5,411
8
Actually wma has always seemed underrated to me, as that has always been better than mp3 for me.
Tiamat
14,068
Ogg has better highs and lows then mp3s. I usually just rip my cds to .wavs though. If i run out of harddrive, i just buy another one - there pretty cheap now-a-days anyways.
Coquito
8,559
Originally posted by: Yanagi
what file size does flac usually land on?
From my experiece, 70-90% of the actual .wav file; pretty large. I have several 2 1/2hr concerts weighing in at 800-980mb. .Shn is also a nice codec, but it's been around for a while, &amp; is being replaced by .flac.
0roo0roo
64,795
84
doubtful that its really better. unless your comparing at lower bitrates. mp3 encoded with lame at higher bitrates is pretty damn good.
Triumph
14
So what's the answer? "At any given bitrate Ogg sounds better..." So which one is bigger at said bitrate?
With those numbers, what's the point? You might as well just leave it as a .wav.
blakeatwork
4,113
Originally posted by: digitalsnare
i rock out to 8-bit midi
Dude... the StreetFighter theme rxors the hizouse!
:D
What's the filesize difference between .ogg and .mp3 at 256kbps? I know a 4 minute 192kbps encoded mp3 can run upwards of 8-10MB...
spacelord
2,127
for a filesize reference, I have a song ripped into OGG. I used a nominal bitrate of 192. (Actual average ended up being 176kbps)
The song length is 4:52, and the filesize is 6,463,608.
sorry, I don't have it ripped into MP3 for better comparison.
I am usually cheap with my filesizes, and I usually rip my OGG at Nominal Bitrate of 160. Even at 128 OGG sounds pretty damn good.
Confused
14,166
If the tracks are the same length then they will be the same size.
Hence the "bitrate" being bits used per second, hence the filesizes being the same.
It's just the Ogg Vorbis makes better use of the file size.
Gurck
Banned
Mar 16, 2004
12,963
^ What Confused said
Damn, wav? At least convert to lossless, that way you're not losing anything, but are saving on size. Another poster said s/he found flac to average 70-90% of the wav size, but I find it to be more like 50-70% - the 70-90% figure was given using live concerts as an example, and live music tends to like higher bitrates, that could be the reason for the discrepancy.
crazycarl
548
maybe it's just my comp, but ~256k ogg encodes much faster than high end lame and sounds about the same to me, that's why i use ogg.
RobCur
Banned
Oct 4, 2002
3,076
:D
bad math
Triumph
14
.wav is lossy? :confused:
blakeatwork
4,113
:D
bad math
Off the top o'me head, a 4 minute .mp3 was running roughly 8-10MB at 192kbps... I could care less about the math.. but if you're so inclined, please provide with the formulas used to determine size required at the various encoding levels.
Thank you.
It was more a question, that you chose not to answer, and instead posit forth an inconclusive statement.
jerk.. :p
pulse8
20,860
:D
bad math
Thank you.
jerk.. :p
5,760,000 bytes
maziwanka
10,415
i wanted to bump this thread so that i could find out what programs ppl use to rip cd tracks to .ogg format
