I found out that
http://www.samsung.com and
http://www.samsungusa.com are 2 diff web pages and the usa.com page has many MORE models than the other.
175V Info link
Model 175V-Black
PANEL Type a-si TFT/TN
Size 17"
Pixel Pitch (mm) 0.264
Brightness 270 cd/m3
Contrast Ratio 450:1
Viewing Angle 150/120 (degrees)
Aspect Ratio 4:3
Response Time 25 ms
Interface Analog
FREQUENCY Horiz. Rate (Analog) 30-81
Vertical Rate 56-75
Bandwidth 135
RESOLUTION Maximum (Analog) 1280 x 1024
Native 1280 x 1024
COLOR Maximum 16.2 Million
SIGNAL INPUT Input Video Signal Analog RGB
Video Level: Analog Analog: 0.7VP-P
Sync Type Separate H/V, Compositive H/V
Input Connectors 15pin D-sub
PLUG & PLAY DCC DDC 2B
POWER On/Working 45 Watts (Max)
WALL MOUNT VESA® VESA 100mm
REGULATIONS Safety UL 1950, CE, CSA, TUV, IEC950, DHHS, PTB
EMI/Emissions FCC, DOC-B, CE, VCCI, Cispr22-B
Emission Standard TCO '95
CABINET COLOR Standard Black
DIMENSIONS Physical (WxHxD) 15.0" x 15.3" x 6.9"
Packaging (WxHxD) 18.1" x 17.9" x 7.9"
WEIGHT Net(Physical) 10.6 lbs
Gross (packaging) 13.6 lbs
FEATURES Special Features Built-in Power
INCLUDED Included Items
OPTIONAL
WARRANTY Parts/Labor/Backlight 3/3/3 (years)
COMPATIBILITY Operating Systems PC/Windows, Macintosh, Sun Microsystems
