Official Avail. Nov 13th - Android 4.2 - LG Nexus 4 - Asus Nexus 7 - Samsung Nexus 10
Discussion in 'Mobile Devices & Gadgets' started by basslover1, Oct 22, 2012.
  1. Gooberlx2
    Gooberlx2 Lifer
    May 4, 2001
    15,384
    Yeah, imo until GV changes this, you're best off getting used to emailing instead of MMS. Since basically everyone I know has a smartphone now, I've found this isn't much of an issue anyway.
    Sprint's MMS integration isn't all that great as it only works between other Sprint subscribers.
  2. Capt Caveman
    Capt Caveman Lifer
    Jan 30, 2005
    34,055
    347
    Thanks to all of you I understand my options now. The issue is that I plan to use my AT&T as my primary number with GV and if I port it over that number will be displayed on Caller ID.
    My unique case is that I would also like to be able to use my original GV number and still have that show on Caller ID and I guess that's why I thought of porting it to ST.
  3. Capt Caveman
    Capt Caveman Lifer
    Jan 30, 2005
    34,055
    347
    Yeah, I use both number for different reasons and different contacts. If I port the AT&T number to GV and keep the original GV number. The original GV number would only be useful for incoming calls due to the Caller ID issue.
  4. lothar
    lothar Diamond Member
    Jan 5, 2000
    6,674
    7
    In that case I think your best bet may be to port one of the numbers to another Google account?
    Capt.Caverman@@gmail.com has "current" Google number.
    Create a new Google account Capt.Caverman2012@gmail.com to get AT&T number and have it ported there.
    Capt.Caverman@gmail gets to keep using that "old" Google Voice number for whatever he uses it for (work, business, etc...)
    Capt.Caverman2012@gmail.com will get new Google Voice number ported from AT&T for whatever he uses it for(personal, etc...).
    You will have to sign in to both Google Accounts on your phone to receive calls for either Google numbers if you do that though?
    #1454 lothar, Nov 29, 2012
  5. Capt Caveman
    Capt Caveman Lifer
    Jan 30, 2005
    34,055
    347
    Yeah, that's a good idea since I'll probably be using my AT&T number 90% of the time. But what happens if I'm logged in as my AT&T number and I get a call for my other GV number? Would it just go to voicemail?
    Oh wait, I could have my old GV number just forward to my AT&T GV number and I would be good to go? I would just need to log into my gmail for old GV number if I needed to dial out?
    edit - I may want to port my AT&T to my current gmail account since I'm always logged into that one. Can I create a new gmail account and port the GV # to that account?
    edit 2 - Yes, I can transfer my GV number to another gmail account - http://support.google.com/voice/bin/static.py?hl=en&ts=1378507&page=ts.cs
    #1455 Capt Caveman, Nov 29, 2012
  6. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,153
    13
    3 hour Nexus 4 Review:
    - FAST. No question. The lower res compared to Nexus 10 allows it to do really well. This was why the Nexus 10 was a bit underwhelming in speed for me.
    - Display is underwhelming. LG Optimus G looked better at the AT&T store. I know they tend to boost brightness to 100% in store but I turned it off. Google needs to learn how to calibrate screens. The Galaxy Nexus was poorly calibrated too. So was the Nexus S. Factory calibration is absolutely WEAK on all these phones. The previous 2 phones had overly blue screens too. My Galaxy S2 definitely looks better and it's completely uncalibrated. My Nexus S colors punch more than my SGS2, yet my SGS2's fail calibration still beats the Nexus 4. Meanwhile my cousin's HTC One X seems to blow all these phones out in terms of quality.
    - Build quality is pretty solid. I like this over the SGS3, but not as much as the HTC One X.
    - I definitely miss root and CyanogenMod. How come google hasn't figured it out that people like a REBOOT option when they hit power? This was like a CM6 option or something, and every freaking OEM has already included this. Good job on being the last one on figuring out the need for better copy & paste flags, multitouch keyboard, group MMS, and now the reboot option.
    - I cringe at the thought of 16 GB of space only.
    Edit
    - I know I've been vocal about not liking soft buttons, and so this is a multipronged complaint. My main complaint was that they don't really serve any purpose or any advantage over hardware keys. It's still a bezel. And with phones like the SGS3 minimizing bottom bezel, you don't need soft keys to maintain that. But before I regurgitate the same arguments, let me move onto something new I discovered today.
    - First, the 3 button choice is stupid. Long press Home is retarded. On my SGS2 it was bringing up the multitask menu. Ok, so Long Press brings me to Google Now. What about the general search feature? I know they're pushing Google Now heavily, but I want to search in all my apps: SMS, Twitter, Maps, Yelp, Foursquare. No way to get to that. Now before I say 3 buttons suck, let's review the SGS3 and SGS2 CyangenMod. Long press home brings you multitasking. Long press Menu brings you Search. Touchwiz might have it different, but you can invoke voice search and multitasking using some combo also. Long press home is an absolute waste.
    - The multitask button to me is not used as much as the menu. I'm not sure why the insisted on removing the menu button. So even if they remove it, it's going to be in all apps anyway, because Android is built that way. You WANT to find that menu button to bring up a menu of buttons.
    - Removing the menu button and putting it on the top is flat out stupid. The menu button is used so much my fingers have to shift around to the top of the phone and bottom of the phone. Remember that with larger phones you have to shift the phone around in your hands. This was ok for me on a 4" or 4.3" platform, but getting to 4.7" it's getting tricky esp with a case.
    - 3 button layouts are not impossible. The SGS phones did it well. Google just chose the wrong buttons. They should've kept the task switcher as a long press home, and then kept the menu button present. Basically, we should be able to access search, home, multitask all from the bottom keys. With a 5" phone like the Note, you want me to reach all the way to the top everytime? Sigh Google.
    #1456 DLeRium, Nov 29, 2012
  7. SpacemanSpiffVT
    SpacemanSpiffVT Senior member
    Apr 17, 2001
    864
    Does android have visual voicemail like the iOS?
  8. s44
    s44 Diamond Member
    Oct 13, 2006
    9,361
    No, better.
  9. basslover1
    basslover1 Golden Member
    Aug 4, 2004
    1,921
    I think it works with anyone that's using Sprint.
    I've only ever received one working MMS using GV, and it was from someone using spring (I had Verizon at the time), and it just gets forwarded to Gmail anyway.
  10. SpacemanSpiffVT
    Apr 17, 2001
    864
    care to elaborate?
  11. bearxor
    bearxor Diamond Member
    Jul 8, 2001
    6,603
    Yes, please. The only type of visual voicemail on a droid I'm aware of is using google voice.
  12. ponyo
    ponyo Lifer
    Feb 14, 2002
    14,566
    355
    If you have two Google Voice number on one account, you can make either number the primary number at any time. All you have to do is log into Google Voice desktop setting and select which number you want primary. You can change back and worth if you wish.
  13. ponyo
    ponyo Lifer
    Feb 14, 2002
    14,566
    355
    I think for your intended use, it's best to go with your original plan and port your number to Straight Talk. You can then use the Straight Talk number and Google Voice number and get 100% functionality. Two Google Voice numbers just unnecessary complicate things.
  14. Capt Caveman
    Capt Caveman Lifer
    Jan 30, 2005
    34,055
    347
    Yeah, that's what I'm thinking, it'll simplify matters.
    But from your comment in the above post:
    Would switching primary number also switch which number was shown on Caller Id?
  15. SpacemanSpiffVT
    Apr 17, 2001
    864
    is anyone else concerned about google releasing a nexus 4 32GB in the near future?
    i am debating cancelling my 16GB order because i would much prefer that.
  16. Viper GTS
    Viper GTS Lifer
    Oct 13, 1999
    37,547
    75
    One thing I'm finding seriously annoying about this phone is the near lack of friction offered by the glass back. I'm discovering just how non-level the places I want to set my phone truly are when it falls off 10 minutes later. The slightest incline is enough to start it sliding when it vibrates.
    I can't wait for Diztronic to release their case just so the damn thing will stay where I put it.
    Viper GTS
  17. Eug
    Eug Lifer
    Mar 11, 2000
    22,241
    148
    Well, they pulled that crap with the Nexus 7, and also dropped the pricing of the existing units just two months later.
    However, I suspect they won't do that with the Nexus 4, maybe because I'm gullible? Fool me twice...
    Nonetheless, if you don't want the 16 GB, I'll take it off your hands. ;)
  18. Red Storm
    Red Storm Lifer
    Oct 2, 2005
    13,661
    70
    Yeah it became instinct for me to super careful with what surfaces I put my phone down on when I had the iPhone 4. Did not like the glass back then and still don't like it now, but the good outweighs the bad by a large margin with the N4 so I can deal with it.
  19. vshah
    vshah Lifer
    Sep 20, 2003
    18,981
    16
    Flash faux123's latest kernel, it allows for some color calibration.
    CM 10.1 nightlies have started for the Nexus 4 :D
    swipe up from anywhere on the bottom buttons gets you google now (faster than long pressing). google now has a search box which will do phone-wide search of all your apps etc. so it's just a swipe a way.
    i also don't like 3 button layouts. once cm10.1 merges all its changes we'll be able to customize the bottom row to our hearts content :D i personally add a menu button down below
  20. Ravynmagi
    Ravynmagi Platinum Member
    Jun 16, 2007
    2,949
    Unless Apple or Amazon comes out with a high end quad core phone with 32GB of storage for $350 (please stop laughing), I doubt we'll see Google add a 32GB model of the Nexus 4.
    I think the only reason we saw Google finally cave and release a 32GB Nexus 7 is because the Kindle Fire HD had 32GB for the same price as the 16GB Nexus 7 and Google got mocked by Amazon for it's "dead on arrival" 8GB model (and rightfully so).
    Amazon is supposedly working on a phone, but I think it'll be quite a while before we see it.
  21. Red Storm
    Red Storm Lifer
    Oct 2, 2005
    13,661
    70
    Google does not make the Note, Samsung does, and Samsung decided not to use the three button soft key implementation so I'm not sure what you mean.
    I prefer the soft keys, they work better for larger phones and make the phones look better IMHO. The way Samsung does it I'm constantly hitting the nav buttons by mistake cause they're on the very edge of the bezel. This is also annoying when I'm using the phone in landscape, I have to basically avoid that side of the phone because of accidental taps.
  22. Eug
    Eug Lifer
    Mar 11, 2000
    22,241
    148
    I really dislike the soft keys. The placement of the home "button" just below the space bar is a user interface fail.
  23. Red Storm
    Red Storm Lifer
    Oct 2, 2005
    13,661
    70
    For what's worth, I never once accidentally pressed the home key when going for the space bar on my Galaxy Nexus, nor on the Nexus 4. I did however, accidentaly press the nav buttons on my S3 quite a bit, and on the smaller Galaxy Stellar (temporary phone) I do it multiple times a day.
  24. Eug
    Eug Lifer
    Mar 11, 2000
    22,241
    148
    I just came across this review of the soft keys.
    ZDNet: Why Android Ice Cream Sandwich's virtual buttons suck
    [​IMG]
    As you can see from the screen shot, the problem is fairly obvious. The virtual keyboard is arranged in such a manner so that the "spacebar" is in very close proximity to the "home" virtual button.
    What happens in these text-intensive apps is that when you are typing and enter a space, your finger tends to accidentally hit the home button instead, which exits the app and sends you back to the home screen.
    To say this is awfully frustrating when you are typing in a status update or when a reply to an email is being composed is an understatement.
    There are a couple of ways these issues can be resolved. First, Google could make a setting within Android to allow the virtual UI buttons for Back, Home and Recent to be re-arranged or aligned further from or closer to each other based on user preference. There's certainly enough white space between these UI elements to permit this on smartphones as well as on tablets.
    The other thing that Google might want to consider doing is offering several different types of keyboard layouts with different button sizes.
    Yes, I'm aware any number of alternative keyboards and data entry methods exist which you can buy on the Google Play store. But the fact that the default text entry method is so broken on Ice Cream Sandwich is a complete failure on Google's part in my opinion.
  25. SpacemanSpiffVT
    Apr 17, 2001
    864
    you know... you make a very very good point.
