Official Avail. Nov 13th - Android 4.2 - LG Nexus 4 - Asus Nexus 7 - Samsung Nexus 10
Discussion in 'Mobile Devices & Gadgets' started by basslover1, Oct 22, 2012.
  1. IHAVEAQUESTION
    IHAVEAQUESTION Golden Member
    Nov 30, 2005
    1,058
    Does JB 4.2 have tethering & Wi-Fi hotspot built-in? If so, do we need to root to use such feature on T-mobile prepaid?
  2. basslover1
    basslover1 Golden Member
    Aug 4, 2004
    1,921
    It's built in and works without going through T-Mobile. However, they might notice you tethering and try to charge you for it. I've used it a few times and it hasn't been a problem but I probably wouldn't make a habit of it.
  3. Eug
    Eug Lifer
    Mar 11, 2000
    22,027
    133
    Pocket-lint:
    http://www.pocket-lint.com/review/6048/lg-google-nexus-4-review-jelly-bean
    Overall phone is great but camera is slow and battery life isn't very good.
    Walt Mosseberg:
    http://allthingsd.com/20121106/nexus-4-is-a-great-value-with-small-improvements/
    Phone is decent, including battery life. Overall an excellent value. No LTE though and Photo Sphere is stupid.
    Trusted Reviews:
    http://www.trustedreviews.com/google-nexus-4_Mobile-Phone_review
    Overall great phone but battery life poor, and camera is disappointing.
    So, would an underclocking app increase battery life? if so, would that necessitate rooting?
  4. IHAVEAQUESTION
    Nov 30, 2005
    1,058
    So say if I root the device, T-Mobile will not be able to detect my tethering & wi-fi hotspot behavior?
    Not planning to abuse the system. Just want to make sure when I am on the road, I don't pay $20 a day in hotel.
  5. vshah
    vshah Lifer
    Sep 20, 2003
    18,981
    16
    Yes it has it,and no root required. Tmobile might detect it and kick you off though.
  6. preslove
    preslove Lifer
    Sep 10, 2003
    16,649
    33
    If you just use it with a tablet for email and browsing, you'll be fine. I'm on t-mo and do it all the time, but don't abuse it. Never had a problem.
  7. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,151
    12
    crappy camera was a huge issue going into this phone. especially after knowing the SGS3 sets the bar for camera quality. Even HTC's One X comes close, but with iPhone 5 and Lumia 920 stepping up the game so much, I don't see how they can release a crap camera.
  8. Eug
    Eug Lifer
    Mar 11, 2000
    22,027
    133
    For $360 CAD, I don't care. My main concern is the crappy battery life. But again, for $360 I might be able to accept that, assuming it is not completely atrocious.
    Maybe that's what Google is counting on.
    I still want to know if underclocking might help though, esp. if it doesn't require a root.
  9. basslover1
    Aug 4, 2004
    1,921
    There may be apps that can mask the appearance that you're tethering a computer, but I don't know if they require root.
    My baseline for smartphone camera is the iPhone 4, it's clearly not up to snuff compared to the newest generation of smartphone cameras, but it's the best I've personally used. As long as the Nexus 4 is as good or better than the iP4 I'll be happy.
  10. Crow550
    Crow550 Platinum Member
    Oct 4, 2005
    2,371
  11. Fire&Blood
    Fire&Blood Platinum Member
    Jan 13, 2009
    2,299
    7
    Can anyone point to a specific reason why the battery life should be worse than Gnex? Besides being my best reference since I own the phone, the screen which draws the most power is similar in size. I have the HSPA+ version and nothing but praise for it's battery life, both under stock and custom ROM's. My GPU is clocked to 384 MHz, CPU has default clocks.
    - 4.7" IPS vs 4.65" AMOLED, very similar screen size and pixel density
    -28nm quad core vs a 45nm dual core
    -2100 mAh Li-po vs 1850mAh Li-ion battery
    Even merely repeating GNex battery life would be enough for me but on paper it's set to exceed it.
  12. ponyo
    ponyo Lifer
    Feb 14, 2002
    14,215
    262
    It's not worse than GNex. The reviews I read cited 3-5 hours of screen time using cellular after being unplugged 12-16 hours. That's similar to what I'm getting with GNex and official extended 2000 mah battery. BTW, GSM GNex has 1750, not 1850 mah stock battery.
  13. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,151
    12
    Can anyone tell me why the Galaxy Nexus 4 performance can be worse than any other phone out there?
    - Quad Core S4 vs Dual Core S4 (SGS3) vs. Quad core A9 (One X Intl).... last I checked Quad S4 > Dual S4 > Quad A9
    - 2 GB RAM vs 2GB RAM vs 1GB RAM
    - Android 4.2
    Just because on paper the phone looks better doesn't mean it's a guaranteed win.
    The Nexus 4 lost in Anand's battery tests against the SGS3 and One X. Maybe it's a fluke, but the fact that it can happen doesn't mean paper specs define the winner.
  14. Crow550
    Oct 4, 2005
    2,371
    I'm sure Google will optimize the OS for the phone. I don't think these were issues noticed when they tested and approved the hardware. So I'd assume some bug popped up.
    Also don't forget most Android devices support USB OTG: http://revision3.com/tekzilla/wii-u...nect-any-usb-device-to-your-phone-#rev3Player
    and http://cnettv.cnet.com/use-usb-devices-android/9742-1_53-50128175.html
    Which if you are worried about the lack of an sd card slot this will allow you to connect all kinds of storage devices like a sd card reader for instance. Then Velcro it to the back of the phone or something lol.
    #514 Crow550, Nov 8, 2012
  15. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,151
    12
    If people complain about 0.5mm extra on a phone, then I don't see how they will tolerate something taped to the phone like a USB reader. The fact is those solutions aren't appropriate for a phone. Perhaps a tablet, but 99% of consumers will tell you that's unacceptable solution. The proper solution is to either bundle enough space to begin with or allow removable storage.
  16. Crow550
    Oct 4, 2005
    2,371
    Yeah or use cloud storage. However we have such a vast selection of phones that if the Nexus 4 doesn't work for one they can always pick something else with an sd card slot. It is what it is.
    #516 Crow550, Nov 8, 2012
  17. Eug
    Eug Lifer
    Mar 11, 2000
    22,027
    133
    The GNex does not have good battery life.
  18. Crow550
    Oct 4, 2005
    2,371
    #518 Crow550, Nov 8, 2012
  19. Fire&Blood
    Jan 13, 2009
    2,299
    7
    I don't think Anand's numbers are the ones to go by. Verge's JT used the GNex as his personal phone for a year and he reports the Nexus 4 has better battery life. Yes, his reviews are shallower than anything Anand and the crew do but in this instance I find him more credible, both for owning the GNex and having a properly functioning unit. A unit that has to sit in the freezer to complete benchmarks is hardy a fully functioning unit.
    At this point, I expect the phone to perform even better than on paper because it will be fueled by all the negativity some people are expressing against it. May even turn into a sentient, possible omnipotent being with a future update. I find it fascinating that after exploring every nook & cranny for a possible flaw, viable or not, people won't stop. I would expect that after concluding a device isn't worth it for them, people walk away and find something better instead f beating the dead horse indefinitely.
    It does for me. I think I'm in the power user category, my coverage both home and work are less than ideal. My impressions certainly aren't applicable to every other user out there but despite relatively heavy usage, I have no problem making it through the day.
    #519 Fire&Blood, Nov 8, 2012
  20. DLeRium
    DLeRium Lifer
    Feb 19, 2001
    20,151
    12
    You just illustrated why subjective evidence is BS. Plenty of people on this board say the Gnex sucks for battery life. Google itself says that. I'm not saying you're lying. I don't have a gnex so I won't comment, but the fact that assessments are all over the place tells you that you cannot rely on something like this.
    Eug posted plenty of reviews with some users saying the battery life rocks, others saying it sucks. Anand's the only one who has objective #s at the moment. Maybe they're wrong, and that's why I think we should wait for more official numbers, but still, I can't blame anyone for being worried. Even GSMArena's "endurance rating" is a load of crap. The SGS2 loses to the SGS3 by 1 hr but for most users, the SGS3 totally outdoes the SGS2 in terms of battery. So I'm not sure what they're talking about.
  21. zerocool84
    zerocool84 Lifer
    Nov 11, 2004
    35,019
    119
    Yup that's why I'm waiting for release to see the real deal results to sell my Kindle Fire and grab one.
  22. Eug
    Eug Lifer
    Mar 11, 2000
    22,027
    133
    Actually the "battery life rocks" assessment is rare. It's usually OK or else poor in the reviews, which sounds like the right ballpark judging by Anand's preview.
    Oh well. Battery life on my 2-year old iPhone 4 isn't good either. I'll just have to accept that my next phone won't have good battery life either. It's a real disappointment considering the other phone I was considering the iPhone 5, but I'm not gonna pay $700 for that.
  23. Fire&Blood
    Jan 13, 2009
    2,299
    7
    I won't bother to look for it but I am positive I posted screens and detailed the battery life of my GNex in the last couple of months. Ultimately, I can't explain why I do and others don't.
    AFAIK, Anand is the only one that had a scientific approach in his battery tests but that's irrelevant if his unit is bad, needing to sit in the freezer to complete benchmarks invalidates the tests he and Brian ran.
  24. AznAnarchy99
    AznAnarchy99 Lifer
    Dec 6, 2004
    14,242
    61
    Idk why everyone keeps claiming cloud when there is no more unlimited internet. Google Play uses a TON of data while streaming.
    For me, over estimating, say I stream 3 hours a day (not entirely true since I have some music on my phone) 2 hours commute and 1 hour gym. This is only three days a week as well. Last month my Google Play data usage according to my GN was 5.1 GB.
  25. Crow550
    Oct 4, 2005
    2,371
    There is some unlimited data plans out there.
    You could download songs over Wifi hotspots.
    Like I said above you have such a vast variety of phones that if the lack of SD slot is so bothersome you can get one that has it.
    Or give a USB OTG cable a whirl.
    #525 Crow550, Nov 8, 2012
