office 2013 uninstall unwanted parts
Anubis
SO i just installed it after getting it from the HUP deal. and i cant figure out how to uninstall all the stuff i wont use, i didn't get a custom install option and the uninstall does not seem to let me choose to uninstall anything separately
i really don't need access and outlook and anything besides Word, Excel and PPT
under programs and features select office 2013, click "change" at the top and you should get an option to add or remove features. from there you can select which components to remove/keep
when i click "Change" i get a popup asking me to repair, Quick or Full
Quick just started doing something. Will try full when this is done
edit: full just reinstalls it
on Win7 if that matters
Yeah, this sucks, I also only need Word, Excel and PPT, other stuff is useless. Especially SkyDrive Pro is annoying as it gets into contextual menus - I see on the internet that there's a registry hack to remove this though.
Uninstall and reinstall and this time select what you want to install. I was able to customize at install time.
The home use deal may depend On the agreement your company has with Microsoft. If you are getting this thru someone else's agreement that may be your problem.
Jim
when you first installed it didn't you see option for custom install where you can install what you want? i am using 2013 and only installed what i wanted
I think it doesn't apply to HUP, at least for some of us. There was no setup.exe that I ran, the installation was from a website and the only customization choice I had was to select 32-bit or 64-bit Office. It may be that I missed the option somewhere, but I doubt it because I always prefer to download installer locally and then run it, and I did not see such an option. Not even an option "where to install".
no no option at the start, the HUP installer is a small 762k file that just actively installs it over the net
when i downloaded it form the HUP site there were only options for 32 or 64 bit
