- Feb 14, 2012
- 345
- 5
- 81
Help me piece the puzzle together. I need help with KVM. From what I have gleaned is there is a a couple of software versions but I don't understand them and from my understanding of virtual machines you can only support 8 machines on Gb connection depending on frame rate. KVM over IP Catx seems to be able to only support One UHD or 1080p x2 (I don't know how it's connected at the client).
I've never had dual monitors besides a laptop screen (too small for me) and a 1080p HDTV.
So next part appears a hardware KVM with displayport (I don't really game but I like 40 inch or bigger screens so that will help out the next part of the explanation).
Can I use something like this to convert the output of displayport 1.2 to HDMI 2.0 https://www.amazon.com/Club3D-Displayport-1-2-HDMI-CAC-1070/dp/B017BQ8I54 and will it not screw up the signal from the KVM switch?
Next, I'm out of touch with graphic cards and I can use the heat in winter so if I can get a card that will display 4K and crunch I could use some advice and I use to buy GPUs in the $200 range so you can date me by that.
I'm now into servers with ecc memory and am looking at building this http://www.techspot.com/review/1218-affordable-40-thread-xeon-monster-pc/
2 CPUs 40 threads any comments?
Bruce
Bruce
