OEM Mobo in an 'aftermarket' case
hazard666
707
I have a dell dimension motherboard that I am trying to install in a Chenming Xpider case and everything seems fine except for the fact that I have no idea where to plug the power/hdd leds, grounding wires and speaker wires to. Would someone be able to help me out? Thank you.
Fern
26,907
174
Well, if nothing else this will serve as a free bump for ya..
I assume the dell mobo is already uninstalled? If not, just check the current wiring and draw your own pin-out chart.
I assume you googled for the info and can't find it. So, have you taken a magnifying glass and looked at the mobo? The ones I have have descriptions printed on the board in very very tiny lettering.
Good Luck with it.
Fern
