Odd XP Problem
misle
3,371
When you are in XP, like on the desktop, and you hit Control - Alt - Del, what are you supposed to get?
This is what I get: PIC
It seems like I use to get more options / different screen.
Am I confused or is something wrong with XP?
NogginBoink
5,322
I *think* you might get bizarre stuff like this if you've installed a hotfix but not yet rebooted. Try rebooting and see if the symptoms persist.
misle
3,371
It's been like this for at least a couple of weeks. I've installed no hotfixes that I know of.
So I'm not crazy and something is wrong... Great :frown:
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Double click on the border of the window to restore TaskMan to it's normal view.
Bill
NogginBoink
5,322
Oh! I know what this is! Double click the border to get your window back to normal.
But you are supposed to get options to lock computer, log off, shut down, etc.
