Originally posted by: soccerballtux
Probably capacitors. Two of my previous computers have done that.
I guess you are right. I get this noise when I maximize or minimize my IE. It gets really loud if i turn my speakers all the way up, they are attached to my monitor. Also it went away once... I dont remember when or why, but it might have happened once after i reinstaller windowsOriginally posted by: gsellis
Experienced this on a desktop. Fixes can include new audio drivers. It can happen with speakers too close to the monitor and poor shielding. Changing your display frequency might also reduce or increase it. Cut the brightness down too if you have it maxed. But if the speakers are right next to the monitor, move them a couple inches away and see if that makes a difference.
