TheBrain77
Sup all,
first some specs
opty 165
ati x1900xt (powercolor oem)
2gb ram (corsair)
asus a8r32-mvp
WD 74gb raptor
winxp
ok. so i got home after work on monday and turned on my system. I walked away for a bit and came back to a blank screen with the monitor light blinking. I was not sure how long i had been away so i figured it just went into sleep and was conserving power. I moved my mouse around and no response. So I reset my box and waited for it to restart.
What happend next was the xp splash screen displayed and then as the windows login was supposed to display. bam the blank screen hit again.
After seeing that happen i was not sure what caused the problem so i went ahead and booted into safe mode. Once there i removed the video drivers and reboot. Sure enough thats solved the problem and allowed me to enter windows. I proceeded to ati to get the latest video drivers and installed them. upon reboot i got a blank screen.
So not im thinking this is great. I found my original driver disk and repeated my steps in save mode. Upon reboot i removed the drivers and installed the old ones. blank screen on reboot.
So now im thinking greater.. I reinstalled windows after repartitioning the hard drive. Installed the original drivers. blank screen.
So now im thinking greater greater. I have attempted several different options and they all yield the same result.. a blank screen. What makes it even worse is that after instaling the drivers on my last attempt. I went into the device manager and noticed that the system was reporting that the drivers were incorrect for the device installed.
any advice? not sure where to go from here
-thebrain
first some specs
opty 165
2gb ram (corsair)
asus a8r32-mvp
WD 74gb raptor
winxp
-thebrain
