mikeymikec
I'm seeing this happen more often with my computer, with various USB storage devices (all external hard disks, one via an enclosure, and the other two are external hard disks by Seagate/WD with USB interfaces), and it's worrying me.
For example, just now I wanted to transfer a large file from my computer to a USB hard disk connected to an enclosure. Windows (7 64-bit SP1) reckoned that the transfer was going at 100MB/sec (bear in mind, USB 2.0), and now it has been sitting there for about two minutes stuck on 80% remaining.
On this occasion there are a heck of a lot of disk errors in the event log (pointing at the external disk), so either the external disk has stopped responding completely or 'other', but on other occasions there aren't any disk errors, and yet a large file seems to get transferred in bursts - transfer for a few seconds at "100MB/sec", then stop for about 10 seconds, then do another burst. Normally I would expect it to max out the USB 2.0 bandwidth and go fairly consistent at that pace (assuming that neither source or destination are getting low on space or are heavily fragmented).
My PC spec:
http://www.mikeymike.org.uk/mikes/mypc.txt
I probably will upgrade my chipset drivers. I don't have any other issues with my system, nor does the event log show anything particularly worrying otherwise.
- edit - I've just reconnected the drive that threw a load of errors, and I'm getting the bizarre transfer behaviour again, though it let me transfer a file to the disk this time. I'm transferring another load to it now, and for a while it was spiking at crazy speeds (460MB/sec, 100MB/sec, etc) then idling for ages, but then it reverted to normal, constant transfer speeds, then went crazy again.
The USB-connected disk I'm transferring to is an old one, a noisy Seagate 400GB, so there's simply no question as to whether it is doing something at a given time or not because the 'click' sound it has given when accessing data has been so obvious since the day I bought it brand-new. I think I'll run a full disk check on it at a convenient time (thanks to MS's belief that Win7's chkdsk consuming all available RAM and slowing the system down is desirable/expected behaviour).
I wonder if this might be an oddity to do with Microsoft Security Essentials in the way that it scans large files. I'm using Process Explorer to monitor disk I/O. I haven't been using it that long, so it may have something to do with it. I just used WinDiff to compare the file I just transferred to make sure the destination and source files are identical, and they are, however it took about two seconds to compare a several-hundred meg file.
My PC spec:
