mikeymikec
I've built two computers of approximately the following spec:
Core i3/i5
ASUS P8Z77-M PRO (BIOS 1805/15 IIRC)
Crucial M4 128GB SSD
Corsair CX430
DVDRW
Coolermaster Elite 342 with front 2x USB 2.0 ports
I've added two rear USB 2.0 ports
These are in a long line of very similar spec computers (the same board), but these two are the only two that have had USB problems - sometimes, when the computer starts, it reckons that one or two USB devices haven't been recognised (one is a USB flash drive I've been using for years, the other is a Logitech RX250 wired mouse).
Thinking about it, there's a vague possibility that it could be the mouse as that's the newcomer (apart from Win8)
If I reconnect the device in question to the same port, it works. I'm definitely only using the USB 2.0 ports so I doubt that it is related to USB 3.0 drivers.
With the previous computer I thought I had fixed the problem by reconnecting the USB connections for the front ports, but now I'm having the same problems on the latest build, I'm not so sure.
I'm going to try reconnecting both USB connections immediately but it seems a bit implausible that I've been hooking up USB ports for years without a hitch and suddenly I get it wrong four times in a row.
Any thoughts/suggestions?
I'll stick to using the same mouse for the time being until the problem reoccurs and then try my trusty MS trackball that I have been using for installs for years.
Core i3/i5
Corsair CX430
DVDRW
