Ive got my Linux box sharing my dialup connection to my Win2k box. I can traceroute fine from my Win2k box, but from Linux it times out on the first hop and each sequential hop. I flushed my IPCHAINS rules just in case that was somehow effecting it, however that had no effect, other than disabling connection sharing. I do not believe it is a Linux problem because if I boot into Win2k and try a trace it crashes the DOS box and takes down Win2k in about 5 minutes. I tried multiple ISP's but had the same results with them. I am at a loss as to what could be causing this. Here is partial traceroutes from each machine:
1 <10 ms <10 ms <10 ms 192.168.0.1
2 140 ms 140 ms 140 ms lvstl2.popsite.net [216.126.156.3]
3 130 ms 130 ms 140 ms stl1-core1-e0-0.popsite.net [216.126.156.1]
4 160 ms 161 ms 150 ms pal-core1-s3-6.starnetinc.com [209.224.141.113]
1 * * *
2 * * *
3 * * *
4 * * *
Both traceroutes were done to the same IP (216.15.129.2), our primary name server at work.
I can trace back to the IP from an outside source fine as well:
13 pal1-core1-f0-0.starnetusa.net (216.126.145.193) 33.181 ms 33.207 ms 40.265 ms
14 lvstl2.popsite.net (216.126.156.3) 56.326 ms 53.937 ms 55.166 ms
15 lvstl2.popsite.net (216.126.156.3) 55.159 ms 54.449 ms 55.573 ms
16 02-074.030.popsite.net (216.126.156.74) 241.291 ms 378.110 ms 219.320 ms
Any ideas what could be causing this? Its much more convient to run a trace from Linux since I allways have an SSH session open to it.
1 * * *
2 * * *
3 * * *
4 * * *
