- Dec 8, 2002
- 2,642
- 0
- 0
I've noticed something a little weird with the temperature readings reported by NVidia's monitor...
-My load temperatures seem to vary from 48C-~56C at different times during the stress test... This may be normal, but it's more variation than I'm used to (although my only other experience is with older Athlons).
-The CPU temperature also varies wildly when I start/stop Orthos/Prime95. My idle temperatures are generally 38-41C... When I start stress testing, the temperatures seem to almost instantly jump to the mid-high 40's, and when I stop the testing, they drop back down again (to~41-45C, depending on how high the load temp was at that point, and eventually setting down to my previously mentioned idle temperatures).
Is this normal, or could it have anything to do with how the heatsink is seated or anything like that?
