I have 2000 nissan maxima with 200k miles on it and at 35-40mph the car will jerk to the right. Once the steering is corrected it drives fine at speeds above that, until you drop back below 35-40mph.
What worn out part on the front end needs to be replaced?
No noise when you jerk the wheel. There is some clunking noise from the front end when going over bumps. Reading overon the maxima forums that it might be worn control arm bushing.
