- Jan 6, 2013
- 386
- 0
- 76
So I have 2 evga gtx 670s (reference) in ski in a phantom 530 with almost ideal airflow. Both cards are on the stock bios and slightly over clocked so they hit the same frequency (1189 MHz)
Now for the confusing part, originally my top card was markedly hotter than the bottom (8C) despite a whole slot between them and PLENTY of airflow. It also had a much higher power percentage in MSI afterburner than card #2 (around 10% higher). Voltages are the same on both cards 1.175v, and the top one even drops below that to stay in its tdp.
I was suspicious that this was odd behavior, so I flipped the cards, and this time the same card was acting up (now at the bottom). Its consistently 2-3C hotter than the top card despite having MORE airflow than it. Keep in mind this is all at the same voltages and clockspeeds. Its TDP is also still higher by about the same amount, despite doing less work as the slave card. Interestingly enough this card also has an ASIC (in gpu-z) of 81% compared to the cooler card's 73%.
So, any ideas?
So, any ideas?
