- Jun 30, 2004
- 16,889
- 2,208
- 126
First, I'm hoping that ASUS honors the "five year warranty" certificate, even for a second owner. But RMA may not be necessary. I'm awaiting their direction -- 48 hours from now.
I had a brand-new tested-good i7-2700K processor. I even had a modest $140 new motherboard for it, but I had been looking for better. Another enthusiast sold me his Sabertooth Z77 with an i5-3570K and 16GB of good RAM. The processor and RAM have been tested in the other board and are tip-top.
I put the SB-K processor in the board after resetting CLRTC. [C2032 battery is under thermal "armor" mobo duct -- will be a bitch to take apart so I can replace or unseat the battery.]
Board doesn't post, but shows the red RAM LED. I press the MemOK! button -- board goes through its configuration cycles. Finally, it posts with "memOK successful . . . F1 to enter setup." When I change the memory parameters to reflect stock DDR3-1600 9-9-9-24 2N and 1.50V, or XMP DDR3-1600 "Auto" timings and voltage, exit-save BIOS results in the same RAM LED light . . . press MemOK! . . . enter BIOS and the RAM is shown at 8-8-8-20, between 1066 and 1071 and 1.55V RAM voltage. If I leave the BIOS alone, the system will post without the MemOK frustration. But I can't set these RAM sticks (so far) to stock settings, or it just takes me through the same ol' MemOK cycle!
I'm wondering if:
1) Most recent BIOS version somehow overlooks compatibility with 2700K.
2) Some obscure setting I've missed.
3) The BIOS PLCC chip is borked.
4) Whether I should flash an older BIOS.
And -- finally -- this is now a second-hand board, no more than two years old, original owner volunteered the use had been "6 hours per day for a year." I got the 5-year-warranty certificate.
So I assume that if I can't fix this with observations 1 to 4, ASUS can. They'll either do it under the warranty coverage or they'll charge me something.
What I know: DDR3-1600 was NOT considered spec or stock and is technically "overclock" for i7-2700K. DDR3-1600 for 3570K IS considered stock. Both processors work another Z77 board, but I never thought to hook up the board with the original processor. I . . wanted . . . my . . . 2700K!!
Someone must have a similar experience or knowledge that will solve the problem. I even have a spare PLCC chip being shipped: I usually pick one up just for troubles like this, but it has most recent BIOS.
Maybe I should go ahead and flash the BIOS with an older version while I wait for ASUS to reply? Thoughts? Insights? Ideas?
I'm wondering if:
