I had a virus on the comp and I formatted (I formatted again and it's still doing the same thing) if I shut down the computer and turn it back on it won't boot says disk failure insert system disk..
If I go into the bios the harddrive is showing up I just click auto detect then save it will then boot fine (sometimes gotta do this a few times) or I put the windows cd in it loads up says the harddrive is missing I go into recovery..still won't detect the drive but as soon as I exit it will then boot up
It's running perfectly no problems while I'm on it but as soon as I shut down it loses it again. Just wanted to see if there was anything I could do otherwise I'll just send it in for RMA it's under warranty.
