odd problem installing XP on a new DM9+
Wigwam
943
have built my system:
2100+xp on a7n8x deluxe [rev2], 1gb pc3200 ram, 120gb DM9+, radeon 9500pro and so i did a clean OS install of XPpro. 1 partition with ntfs file system. After formatting i got a message telling me there is a problem with this partition and XP cannot install on it, so i need to select another partition. When i pressed return i notice that i had a formatted 117GB partition and 8MB of unformatted drive which i presume is what XP had a problem with.
The rest of the installation then continued smoothly.
Even though i am surely not going to miss 8mb, i am concerned this might reflect a more sinister underlying problem - after all: all the components are brand shining new. Aww who am i kidding - i just want my new toy to work flawlessly or at least know why it didnt!
I know that there is sometimes a problem with large drives but i thought this was only a problem above 132gb and havent come across probs specific to 120gb drives so far. At any rate my bios correctly identifies the drive and i wasnt sure if maxblast3 is to get the bios to rcognise the correct size or to help os install [i wanted to avoid using it if possible based on earlier negative comments about it in these forums].
Your input is greatly appreciated
lookin4dlz
688
I had this problem previously. Tried like hell to get around it & couldn't. Finally, to fix it I formatted the drive using FAT 32, then converted it NTFS. I think I then reformatted it using NTFS because I think I remember reading that conversion from FAT 32 isn't the best.
