odd power supply connector
cyraxote
Just replaced the 280-W PSU in my Lenovo desktop with a 550-W PSU from Antec. The old PSU had a little connector with two wires and two pins that connected to a light in the case. The PSU end of the plug says "P9" on it, and the case side says YC and a number I can't make out.
The Antec power supply is modular, so I may be able to get a cable from them for this light, but I don't know what to look for or ask for.
I took some pictures of both connectors. Case end:
https://picasaweb.google.com/lh/photo/92TYpZAc-5-5pvq6VMQEEtMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/IY_wtNBL3aiqVdeP8P8l4dMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/xSY7zqJY4OYl9SEE6eTRWdMTjNZETYmyPJy0liipFm0?feat=directlink
PSU end:
https://picasaweb.google.com/lh/photo/Z5HfPXVh3_t2fkCrFjsWwdMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/8_1Mao-Ju8R0PXgSrWkT0NMTjNZETYmyPJy0liipFm0?feat=directlink
Any ideas or advice would be appreciated.
Thanks.
VirtualLarry
56,587
10,227
I'd say it could be used for RPM monitoring, but that could be achieved with two wires, not three. So I don't know what it is.
cyraxote
It is two wires. And I know that it powers a light in the case. So I know what it's doing, I just don't know what to call it so I can order a cable.
cyraxote
Yes, I've seen that post. In fact, I posted the last message, asking for more details. I've not done this sort of thing before, so I want to make completely sure that I understand it before I do anything.
imagoon
5,199
Something like this might work for you:
http://www.microcenter.com/single_product_results.phtml?product_id=0319764
Use the "5V" side and a small pin to rearrange wires if you need it.
Actually NM it looks like you have a fan controller of some sort
--edit-- below seems wrong---
It looks like it just powers a pair of LEDs on the front panel. I suspect that you might have a ground and 2 5V leads, one makes it blue, the other red and both = purple.
