Windows 7 Home Prem., x64. New Dell XPS 8500...
Has had 3 network (wireless) devices in it.
For testing the first 2, 2 routers were used, an older LinkSys WRT310N, and a newer dual band ASUS RT-N56U.
The first adapter would only connect at 150Mbps. This is an internal device with 2 antenna's at right angles to each other internally at the top of the case.
The second adapter did the same, but if you changed ANY network card setting, it would then connect at 300Mbps. However, upon re-booting it always reverted to 150Mbps.
I should note at this point again that it worked the same with either router serving up the N-Speed wireless signal (WPA2 authentication). I should also note this computer replaced an older HP XP Media Center computer with a LinkSys 14x WMP300N card that always connected at 270Mbps in the same physical location, about 10 feet from the router (both had been used in the past with that system).
Dell, since this is a NEW system has spent MANY hours on the computer physically remotely and has probably messed with every possible setting all to no avail.
So I was sent the 3rd device. Interestingly, since it is dual band, I tried the 2.4Ghz band first as it was set. It connected at 144Mbps???? Odd, but... So I then enabled the 5Ghz band and that SAME device connects at 300Mbps!!!
How can this be? Is there something 'wrong' in the OS limiting the 2.4Ghz connect to 150Mbps (or less)?
The system came with McAfee Security Suite and I've even disabled this to no avail.
Any thoughts or suggestions?
I was thinking it was possibly the fault of the system design, only 2 antenna's, and I know they are connected and the wiring is good. Still doesn't explain why the USB also gets a low connect speed.
Both myself and Dell have looked at the router settings and can't see anything that would LIMIT the connection?
I'm very confused over this?
Irv S.
- Original Dell 1703 N Wireless 1/2 card
- Intel Centrino 2230 Wireless-N 1/2 card
- Linksys USB AE2500 Dual band device
Irv S.
