Odd IP issue
HydroSqueegee
So we have a server on the network. it works great, no problems. That server is connected to a switch which goes to a SAN.
you can ping SERVER from any client PC and get the correct domain IP in reply. if you log into the Server and ping SERVER, you get the private IP of the switch in reply. Not a problem, except its running an oracle database and its causing issues.
if you disable the NIC that goes to the switch (Switch1) the IP will resolve a ping to itself from itself just fine.
So for example, from a client PC:
Pinging SERVER [137.245.165.247] with 32 bytes of data:
Reply from 137.245.165.247: bytes=32 time<1ms TTL=128
From the Server:
Pinging SERVER [192.168.131.4] with 32 bytes of data:
Reply from 192.168.131.4: bytes=32 time<1ms TTL=128
NIC configurations:
Ethernet adapter Team 1:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 137.245.165.247
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 137.245.165.254
Ethernet adapter Switch1:
IPv4 Address. . . . . . . . . . . : 192.168.131.4
HAH! Multi-homed. Changed the interface metric on the 2 adapters to the correct adapter number. Working on 2 of 4 servers with the problem. Fix isnt working on the other 2 that dont have a pair of NICs teamed...
